89-93 12V Cummins Tech Talk '89-'93 5.9L 12 Valve Cummins VE Engine Tech Articles
Good homemade cold-air intake system*
Old Nov 28, 2009 | 10:16 AM
1st genny nut's Avatar
Default Good homemade cold-air intake system*
Hey guys, my truck now is a little restricted breathing wise. Ive been lookin for a good cold-air intake system and the parts to build them. $160 is not in the budget for a factory made one ne suggestions???
Old Nov 28, 2009 | 04:10 PM
BC847's Avatar
Information Stock-Pot Cold Air Box
If you're pulling in hot, under hood air, you're not getting as much power, with lower EGTs as you could otherwise.
If you want to do something "Home-Made", try this . . . .
Find a thin-walled stainless steel soup pot with matching lid AKA: Stock Pot.
Using a Big Honkin Air Filter (BHAF) for your measurements . . . .
Shorten the pot so it's a little taller than your BHAF. Give it about 1/2 ~ 3/4" extra to account for some gasketing. I used some sheet-metal shrinkers (HVAC tool) to make the tube of the pot stick into the bottom once I shortened things.
From there I simply riveted it together.
Then I cut a rectangular window in the pot that would allow connecting it to the front of the truck behind the headlights. I used some thin sheet metal commonly used to make those seamless gutters to make a duct.
Set your BHAF in there such that the incoming air can get around things for even distribution.
Now cut the lid to match the offset filter.
Things should stack-up like this so far.
Now use some 1/2" sheet foam rubber to make a gasket for the lid and a round disc for the bottom of the pot so the filter will be somewhat squeezed snug when you put it all together. I used a couple of small Ell brackets to support the butt of the installed filter. See if you can find some snap-action clips to hold the lid on.
It should look something like this so far .. ..
Old Nov 12, 2010 | 03:24 PM
chromehound's Avatar
Heres how I did mine...
Free stainless pipe, boots & clamps from Airflow Systems, AFE filter from Genos
Around $40 without filter.
Old Nov 13, 2010 | 05:26 PM
1STGENFARMBOY's Avatar
Here is a cheap way to get alot of air,
Dar
shawnecarter
6.0L Performance
Mar 17, 2015 05:49 AM
hoeky22
Jan 2, 2015 04:54 PM
Project_5.9diesel
Dec 11, 2014 09:41 PM
12vbomber
Nov 4, 2014 10:04 PM
petew
Oct 25, 2014 09:29 PM
