HELP New Fuel plate and too much SMOKE?!
Old Nov 27, 2009 | 08:04 PM
mspeer7's Avatar
Default HELP New Fuel plate and too much SMOKE?!
Hey everybody. Maybe one of you can help. I have a 1995 Ram 2500 4X4, Auto, 12V. I just finished a BIG project on my ride. I just changed the timing from 11 to 15. I had the front cover off and re-checked the timing 3 times before reassembling. I replaced my #6 TST plate with a #5 plate and put 3GSK kit in while I had the fuel plate out. Now it idle's great and starts quickly. But it smokes badly and when I bring it up off idle it misses and smokes even worse!! Is it possible that I missed something when I installed the Fuel Plate???? ANY IDEAS!!!!
Old Nov 27, 2009 | 08:26 PM
TwinStackPete379's Avatar
Hate to say it but sounds like timing slipped..You get the shaft super clean and nut torqued to spec?
Old Nov 27, 2009 | 08:37 PM
monster12valve's Avatar
x2
Old Nov 27, 2009 | 08:38 PM
mspeer7's Avatar
Yep, Cleaned it with brake clean and put it together dry. I had the front cover off to do my KDP kit. So everything was right there ?? And I torqued it to 165 ft/lbs is what the timing tool instructions. It starts quickly and idles smoothly? Does slipped timing cause a miss?? Smells and smokes like its over fueling. Think I could have missed something when installing my fuel plate???
Old Nov 27, 2009 | 08:42 PM
12vcummins96's Avatar
sounds like timing to me
Old Nov 27, 2009 | 08:46 PM
Timing. be on the safe side and re-check it. i know its a PITA but you can damage things if it gets real bad. sorry for the bad news fella.
Old Nov 27, 2009 | 08:52 PM
mspeer7's Avatar
Good thing we got a 4 day weekend!! I'll recheck it tomorrow and it is a PITA. Will slipped timing cause it to overfuel?? It was overfueling soo bad that the exhaust manifold gaskets were seeping fuel but only 2 & 3??? and I can't believe the smoke!! Is this comon for slipped timing?? Could I have gotten something wrong when I replaced the fuel plate? or Putting on the AFC housing??
Old Nov 27, 2009 | 08:58 PM
Not saying you cant but it doesnt sound like a problem with the plate. usually problems consist of the foot hanging or actuall heard of them getting stuck. If you got fuel out of your manifold gaskts i would say holy crap.. sure sounds like timimg fella. hopefully someone else chims in too
Old Nov 27, 2009 | 09:04 PM
mspeer7's Avatar
Will have to check it tomorrow a.m. Appreciate the info. Does 165 ft/lbs sound right on the fuel pump gear nut after timing??
Old Nov 27, 2009 | 09:14 PM
I believe so, im not sure tho. it sounds about close. hopefully someone will chime in. mise well make sure what the tq spec is. i dont remember and i dont have my manual here at the house.
do a search for the spec. i know its on here
Last edited by TwinStackPete379; Nov 27, 2009 at 09:15 PM. Reason: forgot sentence
