96 dodge wont start
Old Nov 26, 2009 | 11:04 AM
streetrod's Avatar
Default 96 dodge wont start
i have a 96 cummings diesel that sat for a few mounths and now wont start i have prime to fuel filter cracked lines and gotten small amount of fuel out of them and still wont start?
Old Nov 26, 2009 | 01:31 PM
Whit's Avatar
Site Mascot
hit the primer some more and crank it.............if yer gettin fuel it will run
Old Nov 26, 2009 | 02:15 PM
I agree, crack open the middle banjo bolt and hit the prime button until fuel squirts out (if you use a 12" wooden dowel, it makes priming a whole lot easier on your thumb). Then close the banjo bolt.
Hold accelerator pedal down while your cranking. Its should run, but it will run rough for the first few minutes.
Old Nov 26, 2009 | 05:11 PM
streetrod's Avatar
now it starts as long as ke is in start position as soon as you let off it kills
Old Nov 26, 2009 | 05:19 PM
Ah, then its most likely your fuel shutdown solenoid. Basically, when you turn the key it pulls the solenoid up (you can verify this by actually feeling the solenoid move) - so what is likely happening is that the solenoid is not being held in the run (up) position.
This will explain it a lot better as well as tell you how to adjust it:
Diesel Hard Start Diagnosis
Might need to clean up your linkage and worst case get a replacement.
This should help as well: Name:  12Ve_locations-l.gif
Old Nov 26, 2009 | 05:24 PM
BTW, I would look at chaning all the rubber feul lines on the truck - they are likely dry rotted after 13 years.
Old Nov 26, 2009 | 07:30 PM
streetrod's Avatar
so you think that the selinoid needs to be adjusted not replaced
Old Nov 26, 2009 | 07:48 PM
Yes. That is most definitely the place I would start. I would remove the solenoid, clean it up inside the boot and readjust - that should be your problem.
Old Nov 26, 2009 | 08:26 PM
12vcummins96's Avatar
i agree if you think it is the problem unhook it and put a cable on it and manually pull the lever if it stays running then problem solved
Old Nov 27, 2009 | 10:10 PM
streetrod's Avatar
hay i woulld like to thank all the people who helped me solve this problem you have cured my problem
