jumper cables
Old Nov 24, 2009 | 09:25 AM
bigfish_Oh's Avatar
Default jumper cables
What have you guys ran for jumper/winch cables? I want to put some kind of quick connect at front and rear. Can I ground to frame then run cable off frame at rear or should I run 2 cables. I am thinking #2 welding cable.
Old Nov 24, 2009 | 09:40 AM
PhilipR's Avatar
I have the Superwinch or Warn wiring kit with the slide on connector. It's grounded to the frame and the power wire goes to the battery but through a winch relay on the fire wall and a switch in the cab.
Old Nov 24, 2009 | 09:41 AM
I would go #2 or bigger.
Have a look at this:
https://www.dieselbombers.com/genera...es-deluxe.html
Old Nov 24, 2009 | 10:11 AM
bigfish_Oh's Avatar
that was quick, thanks
Old Nov 28, 2009 | 12:30 AM
robammerman's Avatar
You can also use weather proof hi-lo battery connectors with your own cable.
91 7three
Nov 12, 2014 09:51 PM
