Aluminum Stack?
Old Nov 23, 2009 | 04:01 PM
FIRST GEN. JAKE's Avatar
Default Aluminum Stack?
ive got a piece of 6in. aluminum pipe bout a 1/4 in. thick. i was woundering if it could stand upt to the heat of a diesel becuse i was thinkin of making a stack from it. thanks
Old Nov 23, 2009 | 04:07 PM
12vcummins96's Avatar
i dont see y not
Old Nov 23, 2009 | 04:45 PM
Uncle Bubba's Avatar
Unless it's an actual piece designed for heat over the long haul it wouldn't take it. It would turn white, brittle and eventually crumble. There is different alloy mixtures they use in aluminum just like in stainless and just a piece of general use aluminum wouldn't take it.
Old Nov 23, 2009 | 11:01 PM
BigDiesel359's Avatar
What grade is it?
Old Nov 24, 2009 | 01:14 PM
i have no idea i found it some where. i would think it would be to weak but idk. i was guna paint it with hi temp flat black paint
Old Nov 24, 2009 | 06:33 PM
eastncountryboy's Avatar
i dont see how it could hurt even if it did fall apart, so why not?
Old Nov 25, 2009 | 11:14 AM
well mite be worth a try later on down the road. got bigger fish to fry right now.
Old Nov 25, 2009 | 12:00 PM
good luck
Old Nov 25, 2009 | 10:03 PM
biged681985's Avatar
y would u use aluminum pipe, if ur gonna paint it? one way u could, u could put a 5 inch pipe inside to keep the higher heat out of it. good luck
Old Nov 25, 2009 | 10:17 PM
If it's that thick of walled pipe it's gotta be a general purpose type aluminum. Because of the cost factor involved in the heat resistance tubing it's almost always thin walled stuff like exhaust pipes.
