What is the advantage of head studs?
Old Nov 21, 2009 | 07:38 AM
RamblinWreck's Avatar
Default What is the advantage of head studs?
What is the difference between head bolts and studs? I know one is a threaded rod the other has a hex or some other head.
Are head studs a higher grade of material, grade 8 vs 5 and therefore stronger? Why not just use a higher grade bolt?
Are they larger in diameter so that you have to drill and tap the holes?
Old Nov 21, 2009 | 07:49 AM
mishkaya's Avatar
Studs are usually a stronger material, thus providing greater holding strength. Whether or not they are the same size depends on which ones you get.
Old Nov 21, 2009 | 10:11 AM
So why not use stronger bolts? With studs you would also have washers and nuts, more parts.
Old Nov 21, 2009 | 12:18 PM
mishkaya's Avatar
I am no guru, but I think it has something to do with more precise torque when using studs as opposed to bolts.
Old Nov 21, 2009 | 02:47 PM
Deezel Stink3r's Avatar
In 1983 Smokey Yunick released his book "Power Secrets". He discribed the advantages of studs in the following way: "Heads are flexing with regular bolts due to the play in between the bolt thread and the block thread. This flex is transferred to the bolts and as the bolt loosens up, the head moves even more. High grade headstuds eliminate this problem completely."
A stud is missing the weak point: The head of the bolt.
Common head bolt are usually made of the highest grade of material 12.9 or higher.
ARP bolts, for example, are made of a very high grade steel. Which isn't easy to work with. Those threads aren't cut into the bolt by a lathe, those threads are rolled in the bolt to achieve a higher strength than cutting the threads into the material.
This process costs a lot of money- ARP bolts aren't a bargain. But they provide saftey and peace of mind.
Using studs or bolts depends on the application.
High performance studs or bolts have a predictable amount of stretch. If you follow the recomandations of the manufacturer ( using oil or grease as recommended) you can apply torque to the head very precisely.
Automotive industrie calculates with 1/8 cent. Anything not really necessary is strictly avoided.
Last edited by Deezel Stink3r; Nov 21, 2009 at 02:47 PM. Reason: Automerged Doublepost
Old Nov 26, 2009 | 04:15 PM
BlackedOut02's Avatar
studs are threaded on both ends. one end thread in the block, the other requires a nut.
because it dosnt have as much rotational force, it offers more clamping force. plus they are made of better materials so they are stronger.
Old Nov 26, 2009 | 04:25 PM
12vcummins96's Avatar
if wanting to run high boost levels studs are neserrary so that you dont blow head gaskets
Old Jan 28, 2010 | 01:23 PM
billyrb's Avatar
Yep, studs are the way to go. I put them in every engine I build. I liken it to building a house.....cheap out on the interior paint, but not the foundation and studs for walls.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
turbodiesel123
Nov 28, 2014 08:36 PM
LemayAutoCare
Price Quote - Request A Price
Oct 1, 2014 08:28 AM
