Alot of Blacksmoke
Old Nov 14, 2009 | 10:15 PM
6.5L's Avatar
Default Alot of Blacksmoke
I got a 96 chevy one ton 6.5L. My truck pukes out tons of black smoke enough to coverr the road to where people cant see behind me. Should i be concerned about this? It runs fine and has plenty of power but just wondering if this is bad on the truck?
Old Nov 14, 2009 | 10:44 PM
atuente's Avatar
I would be a little bit cause you can get a ticket for excessive smoke. As long as you get into a lot you shouldn't have a problem
Old Nov 14, 2009 | 11:19 PM
Green Machine's Avatar
6.5s should smoke under normal circumstances. I would check to make sure that your wastegate system is working correctly first. I would also make sure that your air filter is clean and that there is no obstructions in front of the turbo or air intake.
Old Nov 15, 2009 | 12:56 PM
isenegger's Avatar
how do u check the wastegate?
Old Nov 16, 2009 | 10:16 PM
Woody35's Avatar
make sure it can freely move and there is no play in the turbo. for 6.5 who had the first question check to make sure the vaccum system is working
Old Nov 18, 2009 | 11:50 AM
6.5L's Avatar
How would i check the vaccum system to make sure it is working?Now it boggs down doesn't seem like it has any ***** what so ever.
Old Nov 18, 2009 | 09:31 PM
7.3liter's Avatar
it sounds like u need to buy a ford
Old Nov 18, 2009 | 09:43 PM
Woody35's Avatar
when it boggs down does it pour out black smoke. if theres no turbo play your probably not getting any boost and the wastegate is open. wire it shut and drive around for a bit and see if it gets any better. dont drive it like you stole it but normal street driving. look for any holes in the vaccum system or broken hoses
Old Nov 19, 2009 | 12:20 PM
6.5L's Avatar
My dad tried to tell me it was losing power but i drove it today i had no problems..it runs fine but it smokes more than one of my buddys cummins it pours out and i heard alot of smoke out of a 6.5 is bad.?,you can hear my turbo whistle sometimes. but it still has ***** but alot of smoke....my wastegate is fine...where exactly is the vaccum and all these hoses at that you are talking about.
Old Nov 19, 2009 | 06:44 PM
Woody35's Avatar
well if your pouring out blacksmoke i can tell you are losing power. 6.5s cant flow enough fuel to be pouring out black smoke and have the turbo working. the hose going from the wastegate to the front of the engine should be checked. the vaccum pump is in the iddle of the serpintine belt on the bottom. most likely it is not working.
