Air dog help
Old Nov 12, 2009 | 01:15 PM
Heavyduty01's Avatar
Default Air dog help
im installing an air dog 150 on my 2004.5 dodge and my question is the two return lines that are on the fuel filter housing what do i do with them? do i leave the whole filter assy on there and bypass it or should i buy the big line kit and go that route? any help will be appreciated.
Old Nov 12, 2009 | 02:02 PM
The Airdog Kit bypasses the stock filter housing. The line running from your Airdog should connect right into your CP3.
Old Nov 12, 2009 | 02:12 PM
i got that but there are two lines running from the rail to the filter housing with bajo bolts in the middle do i leave the lines off or what?
Old Nov 12, 2009 | 04:45 PM
handymanherb's Avatar
Banned
I left them on and left that all stock, just hook all your lines back up to the tank, I don't know if it uses it but I left it.
Old Nov 12, 2009 | 05:00 PM
Jet A Fuel's Avatar
I don't belive the return lines are on the filter housing at all. Those lines on the filter housing are supply pressure lines from the lift pump.
Like Luke said the Air dog 150 comes with a pickup tube stand pipe and hose kit to increase the supply volume to your injection pump.
I left my stock lines hooked up altho the lift pump and old fuel filter housing is sealed off.
In other words all i would have to do if the air dog ever fails is reconnect the stock fuel supply line from the fuel filter to the Inj pump, plug in the stock lift pump and i can run again on the stock pump to get home.
Old Nov 12, 2009 | 05:42 PM
i just left the filter housing on there and by passed it and hooked all my lines up to the air dog. thanks for the help.
Old Nov 13, 2009 | 09:25 AM
2Tone12V's Avatar
Be sure you have not blocked off your engine and pump return lines. Easy way to find this is follow the small line from the tank up to the front. Had a guy do this with the result of a melted engine. Filled the crank case full of fuel!! TWICE!!! 2 motors in 6 months before the dealer ship called and asked me about our units. Found out he installed it wrong.
Old Nov 13, 2009 | 10:50 AM
Banned
So it is still using that return, I thought so, I just blocked the old pump line and left the rest intact
Old Nov 17, 2009 | 05:03 PM
all i did was block off the filter inlet and outlet to the injector pump and left the return lines on the filter housing and the truck has been running for 500 miles now and no leaks.
Old Nov 17, 2009 | 07:16 PM
12vcummins96's Avatar
those lines are for the injector retuen
dawnrogerl
Price Quote - Request A Price
Jan 29, 2015 01:03 AM
dawnrogerl
Air Dog
Jan 23, 2015 03:09 PM
dawnrogerl
Jan 23, 2015 02:15 PM
Anh Chà n
Jan 9, 2015 12:45 PM
veggyoilkid
Nov 10, 2014 12:39 PM
