Oil Pressure Gauge!
Old Nov 7, 2009 | 11:33 PM
breeze400's Avatar
Default Oil Pressure Gauge!
I have an "02" 7.3 that I want to install A oil pressure gauge. Dose anyone know where I can tap into an oil galley? My oil filter houseing dosen't have A plug where there is sapposed to be one and the Stock gauge location is not pipe thread. Neather is the plug next to the stock gauge. I've been to A couple of parts supplyers but, no one has A clue on what type of treads are in those locations. This is the last gauge to install and I would like to get it going. It came with 1/8" pipe thread fittings! Sam
Old Nov 8, 2009 | 12:39 PM
Deputydog's Avatar
You talking low pressure oil or high pressure oil?
Low pressure has only about 1 place, which is where the sensor is on top the resivour.
If you want a High pressure oil guage, this is what I have and it works great.
DiPricol Optix 0-4000 PSI High Pressure Oil Pump Gauge 94-07 Ford Powerstroke
Old Nov 8, 2009 | 03:56 PM
breeze400's Avatar
QUOTE]You talking low pressure oil or high pressure oil?
Read more: https://www.dieselbombers.com/ford-p...#ixzz0WJ7Xw3Ms
[/QUOTE]
No Low pressure engine oil pressure. Not fuel pressure.[
Read more: https://www.dieselbombers.com/ford-p...#ixzz0WJ7gRsOI
Old Nov 8, 2009 | 04:52 PM
Deputydog's Avatar
Read more: https://www.dieselbombers.com/ford-p...#ixzz0WJ7gRsOI[/QUOTE]
Yeah I knew it wasn't fuel pressure.. That link was for high pressure oil..
Old Nov 8, 2009 | 05:45 PM
breeze400's Avatar
Read more: https://www.dieselbombers.com/ford-p...#ixzz0WJXs61mx
So Then if I can only use the top of the resivare, What kind of thread is that plug there? I know it's not pipe thread witch is what they use for oil pressure gauges. I'm useing Auto Meter Sport Comp Ultra Light Gauges.
PS I can't believe that there isen't A plug somewhere eltz on the block that has oil pressure running at it! Sam LOL
Old Nov 9, 2009 | 01:45 PM
CSIPSD's Avatar
The plug on the top of the HPO res is a O ring boss AN-4 IIRC, it could be a -6 but I am 90% sure its a -4. Any hose shop worth the name will have those parts.
Also there is a plug down by the oil filter, every truck has it, both on the block and on the filter/cooler ***...
I'll see if I can dig up a pic or two.
Old Nov 9, 2009 | 01:54 PM
CSIPSD's Avatar
Here is the HPO res location... You can see the fitting below the 90*
Here is the one on the oil filter/cooler block... Its there, trust me...
I dont have one of the block location... I will have to do some more digging or take a pic off one of the blocks in my shop this weekend.
Old Nov 13, 2009 | 11:18 AM
breeze400's Avatar
Read more: https://www.dieselbombers.com/ford-p...#ixzz0WlDTPu6I
Yes thanks for the information. My oil filter wasen't drilled and taped. I looked there right after I found your pics on Another post. LOL I went to A industrial warhouse. Monday and found some fittings that worked. Not quite the same has your pic but close. If I have time I'll take A pic and post it this weekend.
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
