Lug Nut Tabs
Old Nov 4, 2009 | 02:55 PM
Uncle Bubba's Avatar
Default Lug Nut Tabs
I been noticin here lately the big trucks and buses have some orange tabs on ever lug nut. I'm hopin this is a safety measure to lock them in place and keep em from backing out. If this is the case where do I get some for my truck.
I've had it happen twice in the last few years that my aluminum rims back the nuts off and fall off while I'm goin down the road. Every time I pull my wheels it takes forever to get these things seated back in.
Old Nov 4, 2009 | 07:46 PM
Buck08's Avatar
Just shows if a lug comes loose. All the points go in one direction, if one is out of place, the lug loosened up.
Old Nov 5, 2009 | 09:41 AM
Well that's better then I have right now, anybody know if these are available for our trucks.
I even thought about puttin some lock washers between the wheel and the hub but I don't know that it would help anything either.
Old Nov 5, 2009 | 04:02 PM
MUDDY's Avatar
red locktite dennis
Old Nov 5, 2009 | 04:55 PM
No...you have to heat Red Loctite (262) to 300F to get it off....
You could try the Blue Loctite (242)
Old Nov 5, 2009 | 05:00 PM
Jazz's Avatar
Bubba!!! Don't listen to these guy's. Weld'em
Must be my meds talkin again
Old Nov 5, 2009 | 06:45 PM
cumminsdad08's Avatar
you worry to much, you only run into problems when you stop after your wheel falls off. just keep on the hammer and you will be fine
Old Nov 5, 2009 | 09:25 PM
I tried that. Rollin down the highway at 65mph pullin 8000 pounds worth a trailer behind me. The back end of the truck got kinda wobbly just long enough for me to wonder what was goin wrong when the cannon went off. The rim split in half. The outside half flew all the way across the center median and landed on the shoulder of the oncoming lane and the back half held the tire on with the hub sittin on the road inside the tire. So the tire saved my hub from any real damage.
I had just had new tires installed earlier that day in prep for this trip. Truck didn't roll very well on three wheels.
Now on the other hand I did have an Isuzu Trooper some years back that the half axle broke lose and came off the truck wheel and all. The truck stayed on three wheels rollin down the highway as the tire chased me. It was really rollin along side the drivers side door bouncin off of it as we drove down the highway for a ways.
Aug 15, 2015 02:20 PM
Cervezamoney
Feb 27, 2015 12:39 PM
mt grizzly
Jan 3, 2015 07:58 PM
94ifs
For Sale
Oct 23, 2014 01:24 PM
