305/70/16 too big?
Old Jul 20, 2007 | 11:20 PM
DBogo's Avatar
Default 305/70/16 too big?
are the 305/70/16's too big on a stock dodge 4x4, also do the 94-97 ford alcoa style rims fit with no issue on the dodges, is the offet and all correct?
Old Jul 20, 2007 | 11:30 PM
2141pete's Avatar
I know they fit on my 02 with the leveling kit but i cant honestly remember wich i did first. The wheels may need a bit of machining but i would think that they would work.
Old Jul 21, 2007 | 12:51 AM
The 305's will be too wide for your stock steel wheels...I dont have any useful info about the ford wheels.
In most tires, 295's are taller than 305's and they wont stick out so far. Also, they wont throw crap and road debris on the side of your truck.
Old Jul 21, 2007 | 06:46 AM
2141pete's Avatar
i was told when i bought mine that the 285's and 305's were the same height but the 305's were wider. If I crank the wheel all the way they will rub on the control arms a bit.
Old Jul 21, 2007 | 08:02 AM
scarecrow's Avatar
i do not know how wide stock 95 rims are but as long as they are 16x8 or wider 305s will be fine but they might rub the ower control arm...i am running 315x75x16s on my stock alumm wheels and they do rub the lower control arm...
AutoMerged DoublePost
what ever tire you are looking into buying go onto there website and look for the specs on the tire and it will tell you aproved rim sizes , actual tire size , load ratings , etc......
Old Jul 21, 2007 | 10:26 AM
The stock steel wheels are 6.5".....I think 285 is the biggest you will want to go on them.
Old Jul 21, 2007 | 11:38 AM
scarecrow's Avatar
wow........yea i would have to agree then 285 would be your max size....
Old Jul 25, 2007 | 10:40 AM
hntruckman's Avatar
ive had 305s on mine with no leveling kit i had no rubbing. ive got 285s on it now and i like them better than the 305s.
305s
285s
Old Jul 25, 2007 | 12:26 PM
scarecrow's Avatar
yea but you have aftermarket wheels.....BTW nice truck...
Old Jul 25, 2007 | 02:00 PM
Nitelord's Avatar
I was running 295 BFG all-terrains with no rub. I added the Leveling kit and the 35's fit great. The 35's would not fit before the leveler or the aftermarket wheels. The largest the tire guys would mount was the 295's on the stock rims.
Hope that helps.
Jun 4, 2015 08:40 AM
Feb 2, 2015 03:10 AM
Oct 26, 2014 06:20 PM
Oct 13, 2014 06:10 PM
Oct 7, 2014 04:00 PM
