Dodge Diesel Tech Articles All Years of Cummins Tech Talk
why it shift like that after vb?
Old Oct 31, 2009 | 11:06 PM
bowtech's Avatar
Default why it shift like that after vb?
we put in my sun coast valve body today and starting from a stop it takes for ever to shift out of first and when it shift to 2nd it jumps right in to the next gear fast. Do i need to adjust some thing or what? all the other gears are firmer and shift better
Old Oct 31, 2009 | 11:57 PM
joshmock's Avatar
did you check all the bands while you were in there? maybe it needs band adjustment
Old Nov 1, 2009 | 01:06 AM
davo79's Avatar
What about the tv cable plus most autos don't take off in first they start in second go to third then 4th then od. Also as stated above the bands may be loose in the low end
Old Nov 1, 2009 | 10:10 AM
bowtech's Avatar
how do you adjust the bands? how often do you adjust them i heard adjust them more ofyen if you tow and stuff and it was just rebuilt around 10000 miles ago. how you like those new era injectors davo79? how much where they they the ones you got a real good deal on? what the hp and egts like?
Old Nov 1, 2009 | 10:21 AM
DB Admin's Avatar
Banned
Dodge Diesel Transmission tips
On of the most frequent questions I get on the Cummins powered Dodge trucks is transmission related. The Dodge automatic tranny is very robust and does what it was intended to do very well. But given the reputation for massive torque that the Cummins engine provides, many times the transmission is asked to do far more that the engineers at Dodge designed it to do. The best thing you can do to make the transmission last a LONG time is 1) Don't exceed what is recommended in towing, 2) Change, change, change that tranny fluid and filter, 3) keep the bands adjusted. What? you did not know that the Chrysler rear wheel drive units required periodic band adjustments?
Both Ford and GM use a different system that does not require band adjustment. Just think about it like the comparison between hydraulic and sold cam lifters. One needs adjustment and one does not. But when a solid lifter engine is adjusted properly, just you watch out!
I recommend a fluid change at 10k if you tow heavy. Fluid is cheap compared to rebuilding a tranny. I had a friend some time ago that rebuilt trannys for a living and asked him this. What is the one thing that would put you out of business? He said people changing their fluid often. Automatics get a bad rap, but most people I query on their change intervals brings up one glaring fact. THEY DON'T CHANGE THEIR FLUID OFTEN ENOUGH!
So lets talk band adjustment. The front and rear bands need adjusting at every 24k miles with your fluid change. If heavy towing I would cut that in half. It is an easy procedure once you see how it is done. So follow along with the pics and let me show you how its done....
Keep in mind that these adjustments were done on a '98 24v truck. Depending on the year
Band adjustments for each model year: These were borrowed from the TDR page.
  • 1994
    • Front Band - tighten to 72 in-lb, back off 2-1/2 turns
    • Rear Band
      • 32/42RH - Tighten to 72 in-LB, back off 4 turns
      • 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
  • 1995
    • Front Band
      • 42RH - tighten to 72 in-lb, back off 2-1/4 turns
      • 46RH - tighten to 72 in-lb, back off 2-7/8 turns
      • 47RH - tighten to 72 in-lb, back off 1-7/8 turns
    • Rear Band
      • 42RH - tighten to 72 in-lb, back off 4 turns
      • 46RH - tighten to 72 in-lb, back off 2 turns
      • 47RH - tighten to 72 in-lb, back off 3 turns
  • 1996
    • Front Band - tighten to 72 in-lb, back off 2-7/8 turns
    • Rear Band - tighten to 72 in-lb, back off 2 turns
  • 1997 [From: "Paul R. Haller" To: DiRT]
    • Front Band
      • 46RE - tighten screw to 8N.m or 72 inch pounds, back off 2 7/8 turns
      • 47RE - tighten screw to 8N.m or 72 inch pounds, , back off 1 7/8 turns
    • Rear band
      • 46RE - tighten screw to 8N.m or 72 inch pounds, back off 2 turns
      • 47RE - tighten screw to 8N.m or 72 inch pounds, back off 3 turns
    • The adjustment screw inside the case is a square head bolt. You will need a special 1/4 square head socket to fit your torque wrench.
  • 1998 unknown
  • 1999
    • Front Band
      • 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
      • 42 RE - The final adjustment for the front band has been changed to:
        • back off 3 turns. (TSB 21-16-98)
    • Rear Band
      • 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
      • The 47RH rear band requires a 1/4" hex driver, the front band requires a T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx driver
  • 2000-2001
    • Front Band
      • 42RE - Tighten to 72 in-lb, back off 3 turns
      • 44RE - Tighten to 72 in-lb, back off 1 7/8 turns
      • 46RE - Tighten to 72 in-lb, back off 2 7/8 turns
      • 47RE - Tighten to 72 in-lb, back off 1 7/8 turns
        From Bill Konolday's 47RE notes: I usually go a little looser than factory specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns. Depending on the circumstances I have backed off the band up to 2 1/2 turns.
    • Rear Band
      • 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
      • 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
      • 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
These 2 pics show the lock nut and the adjusting torx T-40 screw.
This is the front band adjustment on the drivers side of the transmission.
Disengage the spring from the lever so your wrench will have some working room.
Back off the nut about 5 turns and then torque the torx screw to 72 inch lbs. Then
I backed off the torx screw (1 7/8 turns). You must do this! Failure to back off the
torx will result in transmission damage! Then re torque the nut 30ft lbs. Don't forget
to re attach the spring to the lever.
Remove the tranny pan and filter to access the rear band adjustment.
Back off the nut about 5 turns and torque the torx screw to 72 inch lbs. Then
I backed off the torx screw (3 turns). You must do this! Failure to back off the
torx will result in transmission damage! Then re torque the nut 25ft lbs.
Install the new filter and pan, refill with ATF+4 and enjoy!
Old Nov 1, 2009 | 11:30 AM
bowtech's Avatar
do you have to adjust both or is there times you only do the front or back?
Old Nov 1, 2009 | 11:32 AM
Jet A Fuel's Avatar
Nice! I like the pictures.
Old Nov 1, 2009 | 11:48 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
thats good chad
Old Nov 1, 2009 | 04:13 PM
bowtech's Avatar
o and it helps if there is enough atf fluid to so its good now i ran it through all the gears and thought got the tc filed up but guess i didnt. but that is a good read up
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
pappyscrapster
Feb 18, 2015 09:44 AM
99stackedpowerstroke
Jan 28, 2015 08:26 PM
