silencer ring
Old Oct 29, 2009 | 12:13 AM
wisakowsky's Avatar
Default silencer ring
is there any way i can take the silencer ring out on a 07 6.7? my buddy asked me the other day figured you guy would know
Old Oct 29, 2009 | 05:14 AM
9412Valve's Avatar
You can, but I've heard you have to break dowels and other things... Also I've heard it'll cause a decrease in performance because on the 6.7's the ring helps direct airflow. I wouldn't mess with it... Just MHO though.
Old Mar 2, 2010 | 07:55 AM
mopar26287's Avatar
i have heard it is all built inot one and if it breaks you have to replace turbo and all, i would get some definate confirmation before i messed with it
Old Mar 2, 2010 | 12:16 PM
ForcedInduction's Avatar
The silencer ring is just that, a silencer. Dodge has them put on to make the engine as quiet and "non-diesel" sounding as possible for their customers.
There is a pin that needs to be drilled out for the ring to be removed.
Old Mar 3, 2010 | 03:07 PM
Horse Power's Avatar
Is this the pin that needs to be drilled out for the ring to be removed? Where is it located at on the turbo if i was to look under the hood? can it be drilled with the turbo still in the truck? Just asking.
Oh did you take it out of your truck?
Old Mar 6, 2010 | 05:43 PM
Yes, thats the pin that must be drilled out. Its easiest just to remove the whole compressor housing.
I had bought one for my Mercedes, but it turns out the HE351 is basically an HX40 which is way too large for my power goals.
6.5jones
6.2L & 6.5L Performance
11
Apr 3, 2017 01:38 PM
Rclemson
Ford Powerstroke 2011-Up 6.7L
Jul 26, 2015 04:10 PM
CumminsAtYa
Mar 28, 2015 06:36 PM
detroitdiesel idi
Jan 2, 2015 02:07 PM
tabascom16
For Sale
Nov 28, 2014 01:48 PM
