looking for some advice from the experienced
Old Oct 26, 2009 | 11:50 AM
BLACKSMOKEMOAN's Avatar
Default looking for some advice from the experienced
I want to get more power out of my truck...so far i have 370inj, DV's, Fuel plate, Turbo, 6olb springs, 3500rpm kit, and the pump is timed. head studs soon... What should i do next other than nitrious? Its a 95 5 speed. Thanks
Old Oct 26, 2009 | 12:13 PM
toy4xchris's Avatar
what fuel plate and turbo you running?
Old Oct 26, 2009 | 12:16 PM
12valvetater's Avatar
a double disk clutch input shaft and hydros
fill out your sig so we can help you better
Last edited by 12valvetater; Oct 26, 2009 at 12:16 PM. Reason: Automerged Doublepost
Old Oct 26, 2009 | 01:03 PM
shortbusdriver's Avatar
what kind of 370's? what size DV's? What plate? What turbo?
all will make a difference
I would get a 4000rpm kit, just cause i really like mine
take the head off and polish n port and o-ring it if your gonna replace the studs anyways.
will eventually need a better lift pump if you plan on pushing more then 500hp
rack plug and AFC mods for full travel would help also
Old Oct 26, 2009 | 01:11 PM
Shea@L&N Performance's Avatar
FormerVendor
Clutch, turbo or two, better injectors, airdog or fass, many options
Old Oct 26, 2009 | 05:11 PM
as far as a lift pump airdog II the ONLY route to go
Old Oct 27, 2009 | 07:56 AM
i got a south bend DD3600 clutch and the $400 imput shaft. I gotta fill out my sig soon. I took my pump off and brought it to a shop here in maine. I told them what I wanted and thats what they did. They get most of their parts from BD. the injectors are marine 370s from bosch. I bought the turbo from a local. Its the power master through PDR. He ran 50psi with it when pulling. I havent put it on yet because i want to wait for head studs. Thank you guys very much for the advice...i need it before i f*ck something up bad
Old Oct 27, 2009 | 09:15 AM
oring the head and stud it
traction bars before you roll the *** end out from under it
and easy on 3rd and 5th their kinda weak
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
leakin 12 valve
Off Roading
Aug 1, 2015 06:21 PM
twm011
Feb 24, 2015 09:11 AM
Mikeyfz45083
Transfer Sled Pulling
Nov 14, 2014 11:04 AM
