Broke The Fitting To The Transmission to Cooler Line
Does anybody have the part number for that little jewel?
Its the brass fitting in the front of the tranny to the cooler.
nobody has anything close around these parts
Thanks in advance
Thanks in advance
no this is just the stock brass fitting that goes into the transmission and connects to the tubing that runs up to the cooler
this one
this one
I think its a 1/2 inch tube.....There is no room to cut the tube and put on a new fitting...the brass fitting has a female threads that are all messed up that the tubes fitting is supposed to screw into.
any idea how much pressure is in the line when running?
my lines are all bent up after a joyus weekend of replacing the tranny
You should be able to go to a Napa auto parts or sometimes other auto parts store and get a fitting. It is 1/2 inch inverted flair to 1/4 pipe. Any hydraulic hose shop would also have the fitting.
