Truck Smoking Bad Turbo Possibly? need help please
Old Oct 25, 2009 | 07:31 PM
jfd1708's Avatar
Default Truck Smoking Bad Turbo Possibly? need help please
the turbo is making noise and the truck lost power and began to smoke real bad. is this a bad turbo charger or is there other things also looking for any advice
Old Oct 25, 2009 | 08:05 PM
12vcummins96's Avatar
yeah the turbo is gone start looking for a new one
Old Oct 25, 2009 | 11:26 PM
Check your intercooler boosts for leaks.
Old Oct 26, 2009 | 12:11 AM
mysterync's Avatar
Also pull the hose of the front of the charger and check for shaft play or damage! We offer rebuilt and used chargers! Give us a call!
Old Oct 26, 2009 | 12:18 AM
It making any boost?
Old Oct 26, 2009 | 01:16 PM
jfd1708's Avatar
no not making any boost and yes there is shaft play is there a rebuild kit available? Thanks for all the advice
Old Oct 26, 2009 | 02:39 PM
mysterync's Avatar
There is a rebuild available, but you may have internal charger damage caused from high boost or egts, even normal wear! I feel concerned that a DIY rebuild can lead to catastrophic engine failure. Not because the DIY guy made a mistake, He just didnt know what to look for.
Old Oct 26, 2009 | 03:13 PM
does it make any noise if you spin the shaft?
Old Oct 26, 2009 | 11:07 PM
jfd1708's Avatar
the only noise is the the blade rubbing where the shaft bearing must be wore out but no other noise had no problems then one day heard a noise and the next the truck lost power and started smoking real bad and missing
Old Oct 27, 2009 | 09:18 AM
mysterync's Avatar
I'd say you've got internal damage! I'd be looking for a charger!
