911 need help asap!
Old Oct 24, 2009 | 12:24 AM
mttjma2002's Avatar
Default 911 need help asap!
2001 Cummins auto 4x4 Edge juice with att, intake, exhaust, and brand new air dog 150. Just installed the AD150 and now im having very very low psi.... like 12psi at idle start up, once i start driving were talking down to 3,2,1,and then at idle after running around 3-4. Code its throwing is the 230, 236 and 1693...the 230 is the one im worried about, transfer pump out of range??????!!!!!! Any help would be amazing guys/girls!
Old Oct 24, 2009 | 02:40 AM
wildbill's Avatar
Wire the pump to a keyed fuse, not the vehicle wiring harness.
Old Oct 24, 2009 | 07:36 AM
mttjma2002's Avatar
Would you mind explaining a little more in detail please? Also when I turn the key on the pump turns on for about 2 seconds and then shuts off?
Old Oct 24, 2009 | 08:21 AM
NadirPoint's Avatar
Did you run a "new" 12V power supply wire to the pump?
Old Oct 24, 2009 | 11:26 AM
mttjma2002's Avatar
The airdog 150 c ame with a new harness with a positive and negative, hooked them up to the battery..... and then hooked a plug into the old fuel harness in the engine bay and then a new connector to the pump new one.
Old Oct 24, 2009 | 01:56 PM
12vcummins96's Avatar
did you install the draw straw far enough in the tank also run the power on wire to a fused key on wire
Old Oct 24, 2009 | 03:44 PM
Recheck your connections
Old Oct 24, 2009 | 11:11 PM
mttjma2002's Avatar
okay so i put the + and - from the secondary battery to the MAIN battery and it fixed it.... hmmmmm kinda weird? But now I got 16-17PSI fuel pressure stable!
Old Oct 25, 2009 | 01:15 AM
Sounds like problem solved. Clear your codes and see what happens.
Old Oct 26, 2009 | 10:51 PM
mttjma2002's Avatar
Now i got smoke blowing out of my air filter what the hell!!!!!!!???????
