Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Prevent Overheating???
Old Oct 22, 2009 | 02:26 AM
cumminoverstrokin's Avatar
Default Prevent Overheating???
I work for a car transport company and we haul three cars at a time with 50 + foot trailers. We only run 12 valves and our trucks are all stock minus exhaust. Had a truck that had 230 horse injectors and an upgraded radiator. ended up blowing the motor because it over heated too many times. We haul from St. George, Ut where its a 100 degrees plus 85% of the year to L.A. and southern Cal where its not much better. Trying to find a way to get more power without chancing motor failure. Just looking for some tips to possibly keep our trucks cool because we have some pretty steep climbs along the way and tired of going 35-40 mph up these obstacles.
Old Oct 22, 2009 | 07:37 PM
tdiezel's Avatar
With the injectors, an upgraded turbo is a must! With upgraded towing turbos you will move more air, have more horse power, and should help greatly with towing capabilities. Im sure you could run a different fuel plate or move it forward or backwards to adjust for optimal results. Even in the stock trucks, if you move the plate forward for more fuel and get a slightly larger turbo, you should be able to tow your loads without over heading because of increased air/exhaust flow.
I guess I should say a towing turbo instead of a larger one
Old Oct 22, 2009 | 07:47 PM
Buckshotmckee's Avatar
Sma't Alec!
You need some sort of air intake to get more air to the beast along with a bigger turbo. You'll also need to upgrade the trans if your running an auto. Your generating wayyyy to much heat for a stock set up.
You need to also need to remember the laws of physics. Your hauling ALOT of weight behind a stock 12v. It will handle it, get you there reliably, but your going to have to be patient. The older 12v were rated somewhere around 11-12k towing capacity. My guess is your somewhere close to 15-16k depending on the cars your hauling.
Old Oct 22, 2009 | 08:38 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
I'm assuming that you don't run a pyro in any of your trucks. Too much fuel not enough air will melt an engine down.
As stated above you will need to match a bigger turbo to the bigger injectors.
Old Oct 22, 2009 | 09:19 PM
Whit's Avatar
Site Mascot
EGT's are almost impossible to control when the AC is on..............move the AC condensor somewhere else and run an electric fan on it , this way yer intercooler wont be preheted with all that hot *** air
Old Oct 22, 2009 | 10:05 PM
12vcummins96's Avatar
you can add a 16 inch electric fan to
Old Oct 25, 2009 | 10:11 PM
Default overheating
thanks guys for all the advice. will start working on some of that **** . Anyone know of a good aftermarket turbo I should use? already using the fuel plate and am going to use the 280 horse injectors. thankfully all of our trucks are five speeds mine actually has a six speed but your guys' advice was very helpful. thank you
Jul 24, 2015 10:30 AM
Brody Olson
Mar 28, 2015 05:14 PM
Andyhc1
Mar 16, 2015 12:00 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
Blue Briar
Oct 5, 2014 08:23 AM
