93 7.3 no start w/out starting fluid
Old Oct 21, 2009 | 08:57 PM
mps's Avatar
mps
Default 93 7.3 no start w/out starting fluid
I have a 93 F250 7.3 non turbo it will not start with out starting fluid when cold. After running it will start right up and runs good. Batteries are good, wait to start light comes on for about 10 seconds then turns off, the engine cranks and im getting some smoke but it will not fire, a little blast of fluid and it starts right up. Im new to deisel repair any help would be great.
Old Oct 21, 2009 | 09:04 PM
Whit's Avatar
Site Mascot
sounds like yer glow plugs are shot or the relays to em maybe
Old Oct 23, 2009 | 08:25 AM
mps's Avatar
mps
i am going to try to trouble shoot the relay and glow plugs i was told by the previous owner put in a used relay but dont know if they got the wiring right they didnt know where to attach the two black leads that are on the same ilet right now they are attached to the base of the gpr i suspect that they belong to a ground but i cant find any wiring diagrahm for help. thanks again
Old Oct 27, 2009 | 04:29 AM
wildbill's Avatar
Please update.
Old Oct 27, 2009 | 09:34 PM
gradyc's Avatar
I would love to know if you find a fix for this. My boss has an 02 f250 7.3 with the same problem. It only seems to do it on his when the weather cools down. I have tested the glow plug system and found it to be perfect but the problem remains. If you figure it out let us know.
Old Oct 28, 2009 | 07:46 AM
DieselDanBoy's Avatar
If you have smoke while cranking that means that its burning something, what color is the smoke? Also if its only when its cold, im garunteeing you its the glow plug relay or the plugs themselves. And try a fuel filter for the hell of it. on the 2002 7.3 it's right on top of the motor behind the powerstroke plastice cover. (fuel filter) and the glow plug relay right behind the filter housing.
Old Oct 28, 2009 | 12:30 PM
gradyc's Avatar
I know it IS NOT the glow plugs on our truck because I checked the glow plugs individually by ohm test and feeding power to each one and checking current drain. I also checked power out from the relay and battery voltage drop with them on. I have been fighting the same problem since last winter. I have also heard other people with a similar problem that the glow plugs tested good. The only solution on ours so far has been to keep the block heater plugged in when the weather gets cold. If you find a solution I would very much like to know to maybe solve ours too.
Old Oct 28, 2009 | 08:32 PM
mps's Avatar
mps
I am going to test the glow plugs and relay tomorrow the relay might be wired wrong looking for a wiring diagrahm or picture to see if its right i'll post what i find out thursday night thanks for the input i'll update thursday
Old Nov 1, 2009 | 07:11 AM
wildbill's Avatar
Updates??
Old Nov 1, 2009 | 10:30 AM
mps's Avatar
mps
Got sick with the flu truck is in the shop waiting for me to get off my butt and look at it ill update as soon as i can thanks for the help
