01 Ram 1500 Gas to Diesel?
Old Oct 21, 2009 | 05:59 AM
01Gasram82's Avatar
Default 01 Ram 1500 Gas to Diesel?
Ok i Have a 01 Ram 1500 gas truck and I wanna put a diesel in it. What do I need to source up for parts and what needs to be done? I tried searching and there is no clear answers. Any help would be appreciatted
Old Oct 29, 2009 | 07:25 PM
the_new_kid's Avatar
Are you still trying to figure out what engine you want to go with or are you trying to decide that too?
There are a LOT of websites that can help you such as 4bt swaps if you want to go with a cummins. they also cover many other small diesel engines like perkins, kubota, ect.
Old Oct 29, 2009 | 08:22 PM
01Gasram82's Avatar
Ok I have gotten a 96 12 valve with auto tranny. Now what else do i need to get? I have the 98 wire harness and pcm. Is everything just going to plug and play or do i have to do anything else?
Old Oct 30, 2009 | 11:48 PM
Well not much is going to be plug and play per say
You will have to splice every wire into the main truck harness to make gauges and other stuff to work.
You will need to fabricate just about everything else but if you want to go expensive you can find just about every part you need to drop that into your truck.
It will be a long road untill you are going to be finished...not to deminish your hopes you will just have to work on it a lot to get it just right.
Old Nov 7, 2009 | 07:02 AM
01Gasram82's Avatar
i did the swap and it runs mint no problems with it. Everything is bolt in and plug and play with the 98 harness and ecm
Old Nov 7, 2009 | 07:52 AM
pocat's Avatar
what did you do to the suspension?
Old Nov 8, 2009 | 06:44 PM
01Gasram82's Avatar
i put the springs from a 96 2500 diesel ram in.
Old Nov 8, 2009 | 09:36 PM
bajabomber87's Avatar
You're going to have to swap the axles out, that dana 44 front is no where near being up to the task of supporting a cummins.
Old Nov 10, 2009 | 06:48 PM
01Gasram82's Avatar
i swapped out the axles and put a dana 60 and 70 in the truck with 410 gears.
Old Nov 11, 2009 | 05:25 AM
pocat's Avatar
pics???
Apr 8, 2015 05:10 PM
Jan 14, 2015 03:40 PM
Jan 13, 2015 09:00 PM
Nov 25, 2014 10:30 AM
Oct 29, 2014 09:30 AM
