Dodge Diesel Tech Articles All Years of Cummins Tech Talk
48RE A/T Trouble Codes (Diesel)
Old Oct 20, 2009 | 12:01 AM
wildbill's Avatar
Default 48RE A/T Trouble Codes (Diesel)
P0711-TRANS TEMP SENSOR, NO TEMP RISE AFTER START (DIESEL.)
P0712-TRANS TEMP SENSOR VOLTAGE TOO LOW (DIESEL)
P0713-TRANS TEMP SENSOR VOLTAGE TOO HIGH
P0720-LOW OUTPUT SPEED SENSOR -RPM ABOVE 15 MPH (DIESEL)
P0748-PRESSURE SOL CONTROL/TRANS RELAY CIRCUITS (DIESEL)
P0850-P/N SWITCH PERFORMANCE (DIESEL)
P0868-GOVERNOR PRESSURE SENSOR VOLTS TOO HI (DIESEL)
P0869-GOVERNOR PRESSURE SENSOR VOLTS TOO LOW (DIESEL)
P0882-TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT LOW (DIESEL)
P0883-TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT HIGH (DIESEL)
P0973-TRANSMISSION OVERDRIVE CIRCUIT VOLTAGE TOO LOW (DIESEL)
P0974-TRANSMISSION OVERDRIVE CIRCUIT VOLTAGE TOO HIGH (DIESEL)
P128B-TCM POWER CONTROL CIRCUIT 2 LOW - TIPM
P128C-TCM POWER CONTROL CIRCUIT 2 HIGH - TIPM
P128D-TCM POWER CONTROL CIRCUIT 2 OPEN - TIPM
P128E-TCM POWER CONTROL CIRCUIT 2 OVERCURRENT - TIPM
P1740-TCC O/D SOL PERFORMANCE (DIESEL)
P1749-TRANSMISSION THROTTLE VALVE POSITION SENSOR CIRCUIT LOW
P1750-TRANSMISSION THROTTLE VALVE POSITION SENSOR CIRCUIT HIGH
P1751-TRANSMISSION THROTTLE VALVE POSITION MINIMUM RANGE PERFORMANCE
P1752-TRANSMISSION THROTTLE VALVE SPAN PERFORMANCE
P1753-TRANSMISSION THROTTLE VALVE MECHANICAL PERFORMANCE
P1754-TRANSMISSION THROTTLE VALVE ACTUATOR STUCK
P1755-TRANSMISSION THROTTLE VALVE CONTROL CIRCUIT
P1756-GOV PRESS NOT EQUAL TO TARGET @ 35 - 40 PSI (DIESEL.)
P1757-GOV PRESS ABOVE 3 PSI IN GEAR WITH 0 MPH (DIESEL)
P1762-GOV PRESS SENSOR OFFSET VOLTS TOO LOW OR HIGH (DIESEL)
P2769-TRANSMISSION TCC CONTROL CIRCUIT LOW
P2770-TRANSMISSION TCC CONTROL CIRCUIT HIGH (DIESEL)
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mar 18, 2015 07:30 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
wolfnexus
Nov 4, 2014 10:04 PM
