No wait to start light...
Old Oct 16, 2009 | 07:54 PM
funnyfarm98's Avatar
Default No wait to start light...
I have a 2000 F250 that the wait to start light will not come on, and the truck will not start either. Also the check engine light just blinks on for a second and goes out??? Anybody run into this before?
Old Oct 16, 2009 | 07:55 PM
12vcummins96's Avatar
did you chech glow plug relay also check grounds
Old Oct 19, 2009 | 02:49 PM
bama29fan's Avatar
i had this happen a few month ago...i changed my oil and filter. when i went to crank it it wouldnt turn over and there was no "wait light". dont know if it was coincidence or not but i turned key on (not crank) and pumped the fuel pedal a few times and held it down for about 10 seconds....kept it held down and turned ignition to off. let go of pedal...waited about 10 seconds....turned it to on and the wait to start light came on....and the truck crunk right up.
this happend two or three time ove the next couple of days and after following this process the truck started up. Maybe coincidence but it worked for me...
let me know how it works for you.
Old Oct 19, 2009 | 03:12 PM
CSIPSD's Avatar
LOL... What the hell brough you to that...
So you have no WTS light and a SES light...
What if any mods do you have? Chipped? programer?
Old Oct 19, 2009 | 08:06 PM
Kyle_KleinSS's Avatar
The ses light will always turn on for a sec when you turn ignition on
Old Oct 20, 2009 | 08:04 AM
bama29fan's Avatar
neighbors dad suggested it after i tried getting it started for a couple of hours....like i said...dont know if it was just coincidence but it worked two or three times?
Old Oct 20, 2009 | 10:23 PM
hillbilliestroker's Avatar
Sorry I dont know the fuse number, but one of the 30 amps fuses for the fuel bowl heater will blow when the heater shorts out and cause a no start with no wait to start light. If you have a blown fuse, unplug the heater at the fuel bowl and replace the fuse.
Old Oct 20, 2009 | 10:41 PM
CSIPSD's Avatar
GOOD CALL!!!
I completely forgot about that damn fuel bowl heater. Good thing I deleted the damn thing!
Old Oct 26, 2009 | 08:44 AM
Default more probs
I have checked out the glow plug relay and it is fine. The truck is now stalling while driving down the road. It is like you just turned off the key...definitely act some sensor is bad, but not sure which one. Once it dies, if I turn the key off and back on and wait for about a minute the wait to start light comes on and it starts right up. Thanks for all the suggestions
Old Oct 26, 2009 | 11:00 PM
Sounds like a crank position sensor. There was a recall on these if you havent already had it done. And the gray ones have been known to give problems, thankfully I havent had any problems out of mine.
schwier94
Sep 26, 2016 09:07 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
bullrideris1
Jan 23, 2015 09:22 AM
NCC74656
Nov 4, 2014 10:46 AM
