Issue with My edge Juice w/attitude
Old Oct 15, 2009 | 10:54 PM
AKchevyman's Avatar
Default Issue with My edge Juice w/attitude
Well I am having a small issue with my setup I have searched and can't seem to find a similar problem. My Edge keeps resetting every time I shut the truck down. The user agreement pops up every time now and gives me the" you have 4 warnings left" then it will count down and restart all over again. My warnings reset and my display setting go back to the stock one. I think it may be a short but just want to know has anyone else heard of this and maybe a fix thank you and you all have a great night
Old Oct 15, 2009 | 10:57 PM
stkdram55's Avatar
check your constant power conection...sounds like you might have a loose wire.
When me and my bro installed his on his 02 (i know people its a different year) IIRC there is a constant power from the battery and then a ACC power that runs with a fuse and just powers the wire when the truck is running??
Old Oct 15, 2009 | 11:08 PM
wildbill's Avatar
Yep, there is a constant power wire and an acc wire. Make sure the constant power is tied to the positive on the battery and the acc to a keyed on fuse.
Old Oct 16, 2009 | 09:04 PM
AKchevyman's Avatar
According to the installation instructions there is only one power wire. It runs off a 15 amp fuse in the fuse box under the hood. I just went under the hood and checked all the connections I turned to key on and off several times after resetting my parameters and it seems to be holding my settings. I will check it again in the morning.
I am not sure what the issue was but it isn't doing it any more. Wish me luck it doesn't do it again.
Last edited by AKchevyman; Oct 16, 2009 at 09:04 PM. Reason: Automerged Doublepost
Old Oct 19, 2009 | 09:46 AM
staarma's Avatar
Maybe use a test light to make sure that the fuse tap is on the hot side of the fuse socket.
Old Oct 27, 2009 | 02:08 PM
skinnysfd's Avatar
You have to put it on the side closet to fender and firewall. it is #50 i believe.
cass_epp
Wanted To Buy (WTB) - Used
Mar 20, 2017 04:07 AM
billy_2tone
For Sale
Jun 2, 2015 06:29 AM
Kfohne21
Feb 16, 2015 03:46 PM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 3, 2014 05:55 PM
