96 powerstroke rough running
Old Oct 15, 2009 | 09:24 PM
coalroller05's Avatar
Default 96 powerstroke rough running
247k on the odometer. completly stock. it seems to run a little rough but not horrible. i replaced the fuel filter due to it being clogged and nasty. cleaned thefilter housing and replaced the lift pump. i can push the accel. pedal all the way to the floor and it will only get up to 15mph in roughly 100 feet or so. it doesnt sound like the turbo is really spooling up, it almost acts like it has an exhaust restriction. its not smoking black, blue, or white. what could it be? im going to drop the exhaust off from the cat back tommorrow to see if that helps. any suggestions are appretiated.
Old Oct 17, 2009 | 07:58 PM
dustys24valve's Avatar
can you spin the turbo wheel by hand and does it freewheel nicely?
Old Oct 19, 2009 | 09:24 PM
wildbill's Avatar
Sounds like crappy fuel. I'd purge the tank and replace with fresh fuel. Also replace the fuel filter again.
Old Oct 19, 2009 | 09:37 PM
Jet A Fuel's Avatar
Air in the fuel system from filter change?
Old Oct 23, 2009 | 10:54 PM
wildbill's Avatar
Updates??
Old Oct 27, 2009 | 04:32 AM
wildbill's Avatar
Please update.
Old Oct 30, 2009 | 05:17 PM
wildbill's Avatar
Closing from no updates.
ssmith.77
Nov 25, 2018 06:56 AM
tim12valve
May 3, 2015 11:02 PM
ssmith.77
Jan 11, 2015 02:03 PM
f250white
Jan 11, 2015 09:25 AM
Fishy816
Jan 11, 2015 08:31 AM
