98 47re stuck in gear
Old Oct 14, 2009 | 01:53 PM
big bolt's Avatar
Default 98 47re stuck in gear
I have had my 98 12v dodge for few years with zero issues. The the other day i hopped in it to run to town and it took off feeling weak. I realized when i got up to 55MPH it wasn't shifting. i pulled over and took off again there were no shifts at all. I tried to pull it all the way down into first to take off next time but it is still in an upper gear. I was wondering if anybody had any idea where to start. i tested the TPS already because i thought it just wasn't goin into lock up at first. I don't know much about these trannys and i haven't gotten any codes read. i have had trouble with the ABS light being on and sometimes the spedometer wouldn't work but it was so intermittant that never have tracked it down. That has been going on for months though.
Any Help would be greatly appreciated
Old Oct 14, 2009 | 02:18 PM
BAD ASS RAM's Avatar
when it does it put it in park then in low and see if it goes to first,i just dad thatr problem and it was the compter($350.00)i put it in drive and it went straight to 3rd than i pulled it in low and still the same thing.i then i put it in park and all the way to low and it went to first and manual shifted.
my speedometer also quit working when the computer died.
Last edited by BAD ASS RAM; Oct 14, 2009 at 02:18 PM. Reason: Automerged Doublepost
Old Oct 14, 2009 | 02:25 PM
DeLuzGN's Avatar
Check your output speed sensor on the tranny.
Check for codes as well, as this will often throw a code.
Mine did the same thing when it went out, so did my dads 99.
Old Oct 14, 2009 | 02:30 PM
big bolt's Avatar
Thanks guys when i get home i'll try to go from park straight to first and see what happens. Is there way to test the output speed sensor? Does it have a specified OHMS resistance?
Old Oct 19, 2009 | 09:14 PM
wildbill's Avatar
Updates??
Old Oct 23, 2009 | 10:45 PM
wildbill's Avatar
Closing thread due to inactivity. Thread starter can reopen.
6.2Lturbo
Chevy/GMC Duramax 01-04 LB7
Aug 15, 2015 01:25 PM
Hotrodd_67
Jun 22, 2015 09:50 PM
Jun 4, 2015 09:30 PM
aoutlaw95
Mar 3, 2015 09:02 PM
rtbcoop
Nov 29, 2014 11:33 PM
