94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
diy ic tubes
Old Oct 9, 2009 | 09:32 AM
twinboys's Avatar
Default diy ic tubes
I just bought a 6.0 intercooler on ebay last night. I was wondering if anyone has fabbed up their own tubes. I wonder if a 3" exhaust bender would work or are the bends too tight? I also thought about cutting and welding to make the bends tighter if needed.
A few months ago, I saw a guy was fabbing them up for a 7.3 or 6.0 and selling them for $150 on ebay. Does anyone know who this was? I think they were aluminum.
I have also seen where someone pieced together tubes from a 6.0 and a 7.3, but I'd rather not spend more money to do this. Thanks.
Old Oct 9, 2009 | 02:11 PM
CSIPSD's Avatar
You can make your own, takes a set of 6.0 pipes and a set of 7.3 SD pipes... You will also need a E99 X pipe to fit your turbo and intake manifolds.
PM "joebob3093" He has some pictures, I helped him install his a year ago or so.
Old Oct 11, 2009 | 10:40 PM
weekendwarriorfsw32's Avatar
Did you ever find out any info on this?
Old Oct 12, 2009 | 03:42 AM
joebob3093's Avatar
Moderator
we used a mix of tubes to make mine, dont know exactly what all we used but we had 2 sets of SD IC pipes and 1 set of 6.0 pipes. we hacked and welded together what we needed to get it to work. here is a picture of what it looks like.
Old Oct 12, 2009 | 12:37 PM
twinboys's Avatar
CSIPSD and joebob3093, Thank You very much for the input.
I found a guy who bends them up for sale and have decided to go that route.
After he finishes mine, I'll ask If he wants me to give his name here-if anyone else is interested.
Since I have never seen one, the picture will be helpful in my next endeavor - fabbing my own spyder. If anyone out there has done this, I'd love to hear about it and see pictures. I think I'll try to keep the two sides more thermally isolated to inhibit heat transfer.
Old Oct 12, 2009 | 01:22 PM
CSIPSD's Avatar
There is no reason to worry about heat transfer. None.
You can fab up your own if you want to, but it is just so easy to throw the e-99 one on there and be done.
Old Oct 12, 2009 | 03:07 PM
twinboys's Avatar
I assume what you mean by "no reason to worry" is that the heat transfer is insignificant.
Is this what you mean?
Here is what I know about the situation:
Heat is transferred from the hot exhaust side of the turbo to the otherwise ambient intake side. Significant enough to warrant use of an intercooler. The charge air travels through the intercooler scrubbing heat proportional to the difference in temperature between it and the ambient. Why cool the charge air at the spyder when it would make the intercooler less affective? Why reheat that same charge air at the spyder before entering the engine?
I do not KNOW the resulting temperature drop of keeping them more isolated, but I do know that it is non-zero. I do not know if it is substantial enough to warrant even trying. If the tight quarters allow it without much difficulty, I will try. If I had an e99 spyder, I would not try.
Old Oct 16, 2009 | 08:11 PM
robammerman's Avatar
Most of the time the insulation is used just to keep the whistle down.
Rooster24v
Price Quote - Request A Price
Aug 26, 2015 06:24 PM
yellow68gto
Diesel Engine Conversions
127
May 4, 2015 01:20 PM
