2006 Dodge Cummins CR w/ code P2146
Old Oct 7, 2009 | 01:45 PM
jjhk915's Avatar
Default 2006 Dodge Cummins CR w/ code P2146
Running rough, no power, and the code I get on my PMT is P2146. I strongly suspect that the bullydog PMT has alot to do with this, but any ideas on what to do/fix it?
Old Oct 7, 2009 | 01:51 PM
wildbill's Avatar
Lemme look the code up, and the reason behind it.
Old Oct 7, 2009 | 01:53 PM
wildbill's Avatar
P2146-BANK 1 (CYLINDERS 1-3) SHORTED HIGH OR LOW
Possible causes
OTHER DTC’S
HIGH SIDE DRIVER CIRCUIT OPEN
LOW SIDE DRIVER CIRCUIT OPEN
HIGH SIDE DRIVER SHORTED TO LOW SIDE DRIVER
HIGH SIDE DRIVERS SHORTED LOW
LOW SIDE DRIVER CIRCUIT SHORTED OTHER LOW SIDE DRIVER CIRCUIT
LOW SIDE DRIVERS SHORTED LOW
HIGH SIDE DRIVER SHORTED TO VOLTAGE
LOW SIDE DRIVER SHORTED TO VOLTAGE
LOW SIDE DRIVER CIRCUIT SHORTED IN INJECTOR HARNESS
INJECTOR
INJECTOR HARNESS
INTERMITTENT CONDITION
ECM
Old Oct 7, 2009 | 01:56 PM
wildbill's Avatar
Remove the injector harness closes to the front of the engine and clean it with some electrical contact cleaner.
Old Oct 9, 2009 | 02:45 PM
jjhk915's Avatar
Thanks for the info....due to some other issues, I towed it to the local shop....better safe then sorry. I've been noticing some white smoke when I start up that clears up after it runs.....I hope it's just the wiring, but if it's a bad injector....what better excuse to upgrade hahahaha.
Old Oct 10, 2009 | 08:37 PM
wildbill's Avatar
Updates??
Old Oct 12, 2009 | 04:48 PM
jjhk915's Avatar
Called the shop today and they had a few more things to check, but they said that it "dosen't look good" will post what I find out as I find out though. I'm thinking worse case an injector got hung open and the motor is toast....dunno
Old Oct 19, 2009 | 09:17 PM
wildbill's Avatar
Updates??
Old Oct 23, 2009 | 10:46 PM
wildbill's Avatar
Closing thread due to inactivity. Thread starter can reopen.
Arog223
Aug 16, 2015 07:15 PM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
Sbboozer
Nov 16, 2014 05:52 PM
Nov 4, 2014 08:10 AM
Oct 24, 2014 02:50 PM
