Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
UNPLUG EGR???
Old Oct 4, 2009 | 04:32 PM
paletazz's Avatar
Default UNPLUG EGR???
I got some advice from 2500megadiesel, that i could get better gas mileage if i unplug my EGR, does anybody know if this will actually help, and if so how do i get this done.
thanks for the help!!!
Old Oct 4, 2009 | 04:38 PM
12vcummins96's Avatar
that will throw a trouble code check and see if they have a delete for it
Old Oct 5, 2009 | 09:20 PM
Superstroker10's Avatar
i wouldnt do it.
if i was you,i'd hit up cobbs diesel performance and get the egr block off plates
but you will also need a custom tuner, so it dont set any codes
Old Oct 7, 2009 | 10:19 PM
snowlvr's Avatar
at this time i dont believe that there are many options here.....Elite diesel carries a full EGR delete with external waste gate, but its spendy and requires taking off you cab....if you dont have a LIFT availible to you your kinda guna have to send the whole truck down to them for the work to be done.........you can shut the EGR off with a tune, although all this does is keep the valve shut or open and does not actually delete anything......i run mine all the time with with both the EGR and DPF deletes in my tunes and love the performance that i get.....give River City Diesel a call, they will hook you up fo sho.............................
by the way unpluging the thing aint guna help ya playa
Old Oct 7, 2009 | 11:51 PM
paletazz's Avatar
thanks to all for the info, im just trying to figure out what tuner to get, seems to me that sct livewire, will work out best, cause of the cost and all, any opinions???
by the way this truck is my daily driver/work truck/toy truck.
Old Oct 9, 2009 | 11:54 AM
SEABEE08FX4's Avatar
The eleite full delete can be done cab on, and a cheaper route would be to do the cobbs block off plates and then get some coolant hose of the same size and reroute the coolant lines so you can full remove the coolers. I'm planning on doing this soon and I will do a write up on it when its done.
syctaz
Jun 26, 2015 12:20 PM
kestmic1
Jun 8, 2015 12:44 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
