95 f350 glow plugs????
Old Oct 1, 2009 | 05:10 PM
BIG H's Avatar
Default 95 f350 glow plugs????
A friend of mine has a 95 f350 that wont start now that its a litlle colder, it blows a lot of white smoke when he tries to start it thinks maybe it could just be glow plugs any advice would be greatly appreciated
also is there a way to test the glow plugs to see if there good or not
Old Oct 1, 2009 | 05:56 PM
joe dirt's Avatar
make sure the batteries are good...test the gpr,..then test the glow plugs one by one by unhooking the harness at the valve covers...dont have the info on here at work,..but someone will chime in soon...or post over in the ford area...prolly get a better response over there...
Old Oct 1, 2009 | 07:15 PM
gradyc's Avatar
There are 2 ways to check the glow plugs. One is to check the resistance with an ohm meter and the other is to take a wire with an ampmeter in it to feed power to each one to check for curent drain. The 2 front and 2 rear wires in the harness are the glow plug wires. The 4 middle wires are the injector wires. I think the resistance reading should be about 2 ohms. If it reads a very high resistance it is open. Make sure that you have power coming fron the relay first. Is the truck using a lot of oil? If it is the o-rings on the injectors could be bad and that also makes it hard starting and blows white smoke.
Old Oct 10, 2009 | 08:41 PM
wildbill's Avatar
Updates??
Old Oct 14, 2009 | 07:09 PM
2500HeavyDuty's Avatar
closing thread due to lack of activity, the OP can re-open the thread if the problem is still there
Metz1234
Mar 3, 2016 10:20 PM
rkp209
Chevy/GMC Duramax 2011 LML
Jan 10, 2016 10:32 AM
GT_Eleanor
Sep 14, 2015 10:52 AM
1997silverado
Mar 12, 2015 07:40 PM
hardwired
8
Jan 23, 2015 04:30 PM
