Water Meth??
Old Sep 24, 2009 | 12:57 PM
CoalTrain99's Avatar
Default Water Meth??
Besides running nitrous...Water meth is it spray after a certain boost or is it push button or what..It seems safer
Old Sep 24, 2009 | 01:48 PM
CSIPSD's Avatar
Most water/meth controlers are boost referace, above your preset boost point the water comes on. Some also have a EGT referance as well.
I have my first stage set to come on at 10psi and second stage at 25psi. I dont like the EGT based systems, because there is always a chance of spraying when you dont have boost which can cause issues with hydrolocking.
Water/meth should not be looked at as a HP boost like nitrous, its better to look at it as a added intercooler.
Old Sep 25, 2009 | 08:53 AM
How do you set it to your boost?? I know the snow stage 3 comes with the controller what about the stage one and 2?
Old Sep 25, 2009 | 01:45 PM
CSIPSD's Avatar
They all have controlers with the kits, I prefer coolingmist to snows. Cooling Mist has better pumps, better nozzles and better controlers. Its just a better kit and much better people to work with.
Water Injection, Methanol Injection, Alcohol Injection Systems | Coolingmist
Old Sep 29, 2009 | 05:37 PM
joe dirt's Avatar
this is a great upgrade if you pull loads alot and need that little extra cooling on long hills...ill be doing a kit of some sort in the future,...
joe,...arnt you running just water?
Old Sep 29, 2009 | 05:46 PM
12vcummins96's Avatar
i am running the aem kit i like it i run 49/51 it brought my egts down 300 degrees and it is a boost referance kit starting psi 10 full is 39 psi
Old Sep 29, 2009 | 06:18 PM
CSIPSD's Avatar
I have done tons of testing with CP equitment... I have in the past run meth for dyno and truck pulls... In the future I will be running water only.
On a PSD, keep it below 40% meth unless you want to see what the inside of the block looks like.
Old Sep 30, 2009 | 12:13 PM
Oh I have seen the inside of mine. dont care to ever see it again
Old Oct 7, 2009 | 01:11 AM
Superstroker10's Avatar
what happened to cause that?
Aug 27, 2015 04:00 PM
Levi2320
Mar 15, 2015 12:05 PM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
89ezgo
Dec 9, 2014 08:58 PM
yams
Dec 7, 2014 12:51 PM
