1993 6.5TD Engine Oil Pan
Old Sep 20, 2009 | 04:18 PM
armenchiloyan's Avatar
Default 1993 6.5TD Engine Oil Pan
Hello All,
When I had my new engine installed, I didnt have the extra money to get a new engine oil pan. The mechanic spent some time fixing the matting surfaces with a hammer, but he told eventually I need to change it. I took my truck for oil change and the guy told me there is a leak from the oil pan. I was wondering is there a way to remove and install a new pan, without yanking the engine out. Or would be better to take the motor out, how hard is it.
I would appreciate any info or input, thank you.
AC
Tacoma, WA
Old Sep 20, 2009 | 05:06 PM
Woody35's Avatar
if its 4x4 you have to take the front axle off and if its 2wd it should be fine right now to take off
Old Sep 21, 2009 | 12:36 PM
Default 93 6.5td Engine Oil Pan
It is a 4x4, and was wondering if its the axle that needs removing or the whole set up. Do I need to drop the front differential as well. Whats the easiest way to drop the whole thing.
Thanks for the help.
Old Sep 21, 2009 | 05:53 PM
Woody35's Avatar
yeah you got to take everything down. if i remember correctly its only 6 bolts. if your careful you could do it on jackstands
burndiesel
10
Feb 7, 2023 01:15 AM
CRCSI
Mar 29, 2015 11:26 PM
98cummins
Jan 29, 2015 08:23 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
98cummins
Dec 9, 2014 10:14 PM
