clutch trans problem!?
Old Sep 19, 2009 | 09:44 AM
19psi's Avatar
Default clutch trans problem!?
So I was getting on the freeway, shifter into 5th, and after a couple seconds, the revs went to 3k and I had no power. So I let off the throttle and get back on, nothing, like it was in neutral. Coasted to a stop, found that no gears work, like I'm n neutral. I can put the trans in gear without pushing in the clutch! Any ideas? Clutch fried? I never noticed it slipping before or nything else weird.
Unless the clutch is stuck off the flywheel I don't see how it can be that. Pedal feels normal.
Old Sep 19, 2009 | 10:25 AM
mysterync's Avatar
Probably damaged the presure plate. Broke an input or clutch disc! You'll have to pull it! For the best deal on a clutch give us a call! 828-266-9077
Old Sep 19, 2009 | 06:58 PM
19psi's Avatar
have you seen that happen before?
Old Sep 19, 2009 | 07:15 PM
Has the clutch been slipping?
Old Sep 20, 2009 | 11:09 AM
19psi's Avatar
nope, never had it slip. i towed my jeep last weekend up some decent hills at 72mph in 5th and no slippage at all.
Old Sep 20, 2009 | 03:39 PM
gradyc's Avatar
It sounds like it is more likely to be either the clutch hub broke loose from the disk or a shaft broke in the transmission. My money would be the clutch disk broke.
Old Sep 20, 2009 | 05:09 PM
mysterync's Avatar
Very common failure in stock clutches, even in a non modified truck!
Old Sep 20, 2009 | 05:46 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
if you need one give us a call.
Old Sep 20, 2009 | 06:32 PM
19psi's Avatar
that's prettry much what i've narrowed it down to, we'll see once i get the trans out. that x member was a motherf*cker! i used a car scissor jack to press it out. no idea how i'm going to get it back in....
i'd defi itely prefer it to be the clutch disk.
good info, never heard that before.
i'll definitely be checking around when it's time to buy...
Old Sep 23, 2009 | 06:32 AM
19psi's Avatar
found the problem, after getting hte trans out last night. clutch disc broke into a million pieces.
thanks everyone.
