BOG DOWN 6.0
Old May 3, 2008 | 03:16 PM
XLR8's Avatar
Default BOG DOWN 6.0
MY 6.0 FORD F-250 HAS NO POWER AT FIRST. AFTER I DRIVE IT FOR A MILE OR SO IT SEEMS TO RUN FINE. DO I NEED NEW INJECTERS OR JUST A REPROGRAM OF THE COMPUTER?
Old May 3, 2008 | 03:30 PM
What kinda modifications have been done to your truck? How long since you changed both fuel filters? Any Codes found on computer?
Old May 3, 2008 | 04:47 PM
JON's Avatar
JON
Member
Default Bog
Is this after it has sat for a bit? 99.9% chance it needs the latest calibration for cold start concerns. That is if it hasnt gone long enough to actually damage the internal parts of the injectors.
Old Sep 17, 2009 | 12:39 PM
CoalTrain99's Avatar
getcha a 7.3!!!
Old Sep 17, 2009 | 08:56 PM
Big Angry Hillbilly's Avatar
What's the maintenance history like - the oil not getting changed as often as it needs to be can contribute to this.
Old Sep 21, 2009 | 09:56 AM
GDief's Avatar
I gotta ask what year is the truck? My 04 was notorious for this. Also doesn't every 6.0 sluggish at first when you start out unless you warm it up quite a bit. I've been told that it's a Ford and live with it.
Old Sep 21, 2009 | 02:02 PM
churkeepwrstrke's Avatar
My 05 sometimes runs a lil rough until it gets warm. but after that its fine. its usually after it sets fora few days. normal i guess?
Old Sep 21, 2009 | 07:06 PM
smokindiesel79's Avatar
I had this problem, it got progressively worse until it would actually die on me. Turns out it was the wiring to the ficm chaffing and grounding out, the thing that really stumped me is the fact that cold mornings made the problem worse, would have no problems in the afternoons, my truck is an 04' built in 03' with an 03' motor. I would see if they have rerouted the wiring yet on your truck, they told me where the wiring was run from the factory ceated the problem. When I picked the truck up and they told me what they had done to fix it I did not believe it was fixed, but problem has never returned.
BeastFromTheEast
Aug 4, 2015 10:06 AM
DoctorJJ
Jun 9, 2015 08:07 AM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
