Dilemma
Old Sep 16, 2009 | 12:57 PM
01trailerpuller's Avatar
Default Dilemma
I have an 01 Cummins with a stock Turbo and a Pacbrake. I am looking to upgrade my turbo but I would no longer be able to use my current Pacbrake. They do not make a kit for it with a bigger turbo and I would have to buy a whole new system and install a compressor (current one uses vacuum) into my truck to have an Exhaust break again. Does anyone have any suggestions?
Old Sep 16, 2009 | 01:02 PM
Red_Rattler's Avatar
High Tech Redneck
I have the same problem I know SOME will allow the use of the brake can't remeber what ones but the sponcers will hopefully chime in and tell us
Old Sep 16, 2009 | 01:26 PM
Wyatt Earp's Avatar
It depends on the aftermarket turbo. I know that with some flanges and such that a PAC will fit on just about anything. The question is will there be space to get it to fit between the mount and the fire wall.
PAC makes all sorts of bits and pieces. Give them a call in Canada and see what they say.
Old Sep 16, 2009 | 01:39 PM
mysterync's Avatar
You need adapter kit C11432
Old Sep 16, 2009 | 01:41 PM
According to PAC if I get an aftermarket turbo with a 4" exhaust (which is what I am looking at) my current exhaust brake will no longer bolt up do to the fact it is for the 3". All of the 4" kits from PAC require a compressor since they run on air not vacuum.
Old Sep 16, 2009 | 01:50 PM
mysterync's Avatar
Ohhh...I see what your talking about. What part number brake do you have currently?
Old Sep 16, 2009 | 02:55 PM
I don't know the part number and PAC says they no longer make the vacuum type.
Old Sep 18, 2009 | 07:55 PM
stokethis24's Avatar
the brake will bolt to a hx35 hybrid they have a hx40 compressor with the 35 outlet you can get them at high tech turbo an if you send it to them they will do it for you for 85 bucks
