injection pump 2002 7.3
Old Sep 15, 2009 | 03:48 PM
7.3_stroker's Avatar
Default injection pump 2002 7.3
can you turn the pump up for more smoke? Is this safe to do thanks let me know please
Old Sep 15, 2009 | 04:24 PM
CSIPSD's Avatar
There is no "pump" on a 7.3 powerstroke. Your injectors are fired by high pressure oil supplied by your high pressure oil pump. It is controled by the IPR by the PCM. You can do a 10k mod (adding a 10k resistor to the ICP sensor lines). With your edge tuner, I would not do this as edge jacks the ICP pressures already.
Start looking for a chip that plugs on to the PCM, 6 settings on the fly, much better tuning and better tranny controls. Edge does nothing for your tranny.
Swamps is who I use for all my tuning, but there are several good companys out there.
Old Sep 15, 2009 | 08:01 PM
what feeds the lift pump??
Old Sep 15, 2009 | 08:26 PM
Superstroker10's Avatar
there is no lift pump, just a High Pressure Oil Pump and just a fuel pump mounted on the
frame for FUEL
Old Sep 15, 2009 | 08:30 PM
thank you i was confused. nice truck btw
Old Sep 15, 2009 | 08:48 PM
CSIPSD's Avatar
Fuel gets to the injector with low pressure fuel pump at about 55-70psi, then the HPOP pressurizes the injector and pushes the fuel out of the nozzle when the time comes... Over simplified but...
Old Sep 17, 2009 | 09:03 AM
CoalTrain99's Avatar
No Injection pump just run nitrous! completely safe
Old Sep 17, 2009 | 11:16 AM
CSIPSD's Avatar
Is this some inside joke with the two of you? I hope so, because what your saying is completely untrue.
Old Sep 17, 2009 | 12:20 PM
One time i sprayed a 120 down I 10 and went through the median
Old Sep 17, 2009 | 09:25 PM
he isnt lying....it went completely sideways it was badd
