2000 f150 gas to diesel conversion
Old Sep 15, 2009 | 12:52 PM
portugeedave89's Avatar
Default 2000 f150 gas to diesel conversion
i have a 2000 ford f150 5.4L V8 4x4 single cab long bed. iv been wanting to put a 7.3 in for a while now. i was wondering how possible it would be. i'm already upgrading the front suspension. im converting it to a solid axle(Dana 44) from a 78 bronco. if needed ill box in the frame if not already and add extra cross members. i was planning on buying a donor truck thats running and pull the motor out with transmission and install in my truck. if im missing anything here let me know and some helpful tips would be great. thank -
Old Sep 18, 2009 | 08:23 PM
tdiezel's Avatar
You should be able to fit it but may require a bit of firewall removal. It will also be a very tight fit for the parts in the compartment. the F150 has a slightly smaller body width and length from the F250 and F350 but seems possible to me. I believe it will fit, maybe tightly but it should. You shouldn't have to box the frame either.
Old Sep 19, 2009 | 12:39 AM
Diesel-Nut's Avatar
The 4bt cummins would be a better engine in my opinion. The 7.3 is pretty heavy.
Old Sep 24, 2009 | 06:52 PM
zjohnsonua's Avatar
^^^^ what he said. I would think you could start having some scary front end issues
Old Sep 27, 2009 | 09:11 PM
What trucks have the 4bt cummins in them and will it bolt up to my transmission
Old Oct 5, 2009 | 11:17 PM
Diesel-Nut's Avatar
Most step vans have them. You will have to have a bell housing adapter, flywheel, and if you have an auto trans, a trans shift controller.
Old Jun 5, 2011 | 09:47 AM
kayok's Avatar
How about ford's new ecoboost 3.5 diesel engine. It is currently being use in Ford's f150 and Taurus. I have a 2002 f150 with 5.4 v8 engine and is thinking of a gas to diesel swap as well. Does anybody know what kind of problem I will encounter if I'll do this swap? Any information or suggestion will be appreciated. Thank you.
Old Jun 6, 2011 | 09:49 PM
Diesel-Nut's Avatar
Sorry there dude the ecoboost is a gasser. Twin turboed direct injected GAS engine. Like was said before the best diesel to put in these half tonners is a Cummins 4 bt. They weigh in at 750 lbs. It'll be an expensive swap for sure. There is a fella on here that swapped this engine into a 2wd F150 but he used a 5 speed trans not an auto. In my opinion I wouldn't do it. It's not really worth all the effort. You'd be better off buying a truck that's already a diesel. I thought about doing the same thing your doing about a year ago but changed my mind. I just bought a diesel truck instead. But if you go ahead and actually do the swap good luck to ya.
Old Jun 7, 2011 | 10:51 PM
kayok's Avatar
You are right, ford's 3.5 ecoboost engine is a gas engine. My mistake.
Diesel Guy23
Oct 18, 2015 11:41 PM
Angeliruo
Oct 8, 2015 08:24 PM
diggybiggs
May 14, 2015 11:51 PM
Oct 31, 2014 06:10 PM
Oct 30, 2014 08:10 AM
