fuel plate specs
Old Sep 12, 2009 | 02:08 PM
FastCR's Avatar
Default fuel plate specs
Has anyone done the measurements and math on rpms vs rise on the fuel plate? I need to get mine back in until i get the bigger turbo in so i can do over 55 on the freeway up a hill under 1100*
I'd like to actually make a correct one for where I want fuel.
Old Sep 12, 2009 | 02:53 PM
xzaq103's Avatar
FormerVendor
Im not sure if anyone has those measurements. What pump do you have? Im going to guess its a 215 seeing as how you have 215 injectors. What is your current AFC setup?
If you have a 215 pump I would suggest a #11 plate. Then pull spme more fuel out of it with yoour AFC setup.
Old Sep 12, 2009 | 04:33 PM
FastCR's Avatar
nope 180 pump, picked up the 215 sticks for $120. Right now the AFC spring is all the way loose, tuning it is on the to do list, but i'm getting so much fuel with so little turbo right now, I want to leave the plate fat just up to freeway cruising rpms so they will stay low going down the road, then basically right angle right over it to a 0.
Old Sep 22, 2009 | 07:58 PM
Beets's Avatar
Have you changed your timing? i bumped mine to 17.5* and i only run about 700 to 800 and i have alot more fuel then you do.
Old Sep 23, 2009 | 10:04 AM
Hammer's Avatar
Loose AFC Spring=Alot Of Low End Fueling which will make EGT's high.
Tighten the spring up and go from there.
Personally.....
Being that your in Arizona I would not have a 0 plate in for daily driving.Way to much plate to run the Flag with and expect EGT's to stay managable.
Old Sep 23, 2009 | 02:10 PM
FastCR's Avatar
Its on my to do list. the shops around here want more than the cost of a timing set to do it, so my buddy is hooking me up with snap on set for cheap.
Personally.....
Being that your in Arizona I would not have a 0 plate in for daily driving.Way to much plate to run the Flag with and expect EGT's to saty managable.
I'm actually in MT now so its not so bad. I put a bigger actuator on the wastegate and now its a lot more manageable. as long as I can keep rolling 80mph I'm fine, its the acceleration from ~65-80 that is killer.
Should have the timing set within a couple weeks, and new turbo on within a month. I was just hoping someone had measured it out like a guy on compD did on the whole AFC.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
