Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
I Need Wiring Help!!!!!!!!!!!
Old Sep 11, 2009 | 05:02 PM
cummins army's Avatar
Default I Need Wiring Help!!!!!!!!!!!
ok too start off the trailer wiring is good confirmed that with my friends truck but the wiring on my truck is out of wack the trailer brakes wont work at all can some one send me a color diagram on the way my truck is supposed to be wired so i can make sure its right and i do have gooseneck hook up in the bed i have the 7 pin round rv connectors for both just any help is useful its on my truck in the sig trailer brake controller is a hayes genesis please help
Old Sep 11, 2009 | 05:04 PM
wildbill's Avatar
https://www.dieselbombers.com/towing...ug-wiring.html
Old Sep 11, 2009 | 05:50 PM
lunk's Avatar
theres a fuse under the hood in the engine bay to put power to the trailer brake controller its the trailer 40 amp i would check that to start
there s also fuses inside the truck for the trailer lights check those
Old Sep 15, 2009 | 07:15 PM
Uncle Bubba's Avatar
Is this the factory wiring harness or an add on. If it's factory it's best to check it in the main connection, under the truck at the back side of the front fender well is where it all connects in.
If it's factory also make sure it is still plugged in under the dash.
Old Apr 6, 2010 | 10:30 AM
ugly truck's Avatar
Hit the craft shop and have then get it for you they should have it on their computer and they should have the test equipment also. hopefully its not like the rest I have ran across here lately.
Old Apr 20, 2010 | 11:27 AM
millco's Avatar
How did you make out on this?
If any of you need any help with this, let me know! I have some wiring (Read: Shop Manuals!) diagrams for some of our trucks!! Be glad to help if I can
Old Apr 20, 2010 | 11:31 AM
12vcummins96's Avatar
any luck
Old Apr 23, 2010 | 08:14 AM
thanks guys we got it
Old Apr 29, 2010 | 08:45 AM
Hey Dan, I'll take any downloads or links to truck guides you can give me.
Old May 24, 2010 | 05:25 PM
millco's Avatar
Well my friend, I'm sorry I missed your post here. What with being on the road and all....
I have FSM for '01, '03-'06 and I think a '94. They are large enough that we would have to use a file sharing program. I joined one to be able to share one of these... Right now I can't remember what it is. I will find it and if you want that might be the easiest way to share the ones you would like to have. It's too bad I didn't make it by! Could have just plugged in a thumb drive while I was there! . . . Maybe we will have to come back.
As far as links go.... I guess I could make up a file to share. I have a very large amount of bookmarks for websites. I have a ton of info on Cummins!! I have been working very hard at gathering info and as of late I have realized how much I need to work on organizing it so it will be useful!
cumminspwr11
12
Oct 17, 2021 03:50 AM
ofelas
11
Aug 12, 2015 07:23 PM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
Mike H
Nov 25, 2014 03:13 PM
