Triple Turbo Compounds Are Done!
Old Sep 8, 2009 | 03:22 PM
JD WOP's Avatar
Default Triple Turbo Compounds Are Done!
Well, figured since we were out showing them off at the dyno event at Edge Saturday, I just as well post some pictures. These are just a couple teasers of what's under the hood. I will say this, pictures don't do it justice. Zane and Moose at Wide Open have definitley out done themselves this time.
This setup is good for 50 to 100 pounds of boost. I have hit 60 psi on smarty level two. Still have to do some tuning to the wastegates to get them where we want. Also they start to spool at 1400 rpm's.
Old Sep 8, 2009 | 03:26 PM
nyredcummins's Avatar
That is great! What do you think they are going to put out for horsepower? What injectors are you fueling with?
Old Sep 8, 2009 | 03:32 PM
JD WOP's Avatar
These turbos are caplable of 50 to 100 psi, I am probably around a true 650. I have DDP 90hp and a small cp3, once we get the wastegastes dialed in I will look into adding some fuel. Right now it is virtually smoke free.
Old Sep 8, 2009 | 08:17 PM
Camotanker's Avatar
OMG! they fit!
where is the bottom turbo and how big is it?
Old Sep 8, 2009 | 08:25 PM
BHaner's Avatar
OMG!!! IS that really the Camotanker???
Old Sep 8, 2009 | 08:28 PM
dirt diggler's Avatar
wow
Old Sep 9, 2009 | 10:35 AM
JD WOP's Avatar
Originally Posted by Camotanker
OMG! they fit!
It is directly underneath the other two, not sure on size I never did measure it. Not sure knowing the mm would help much that measurment really doesent tell you much about a pius turbo.
Old Sep 9, 2009 | 11:33 AM
Jonny's Avatar
"No, they aren't twins! They're Triplets!!" Now how many people can say that!
Old Sep 9, 2009 | 12:45 PM
nosparkCummins's Avatar
Your License plate should be "3some"
Old Sep 9, 2009 | 12:51 PM
JD WOP's Avatar
ha ha thats funny i am already working on that
