Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Recall Notice Mopar Steering Linkage
Old Sep 5, 2009 | 09:59 PM
retirednak's Avatar
Exclamation Recall Notice Mopar Steering Linkage
Sorry if this is a repost.
2003-2009 Dodge P/U
During a prior service appt, a Mopar service parts steering linkage may have been installed on your truck. The drag link inner joint may fracture under certain driving conditions. This could cause a crash without warning! Also the steering damper bracket at the tie rod tube may loosen. This could cause the bracket to slide on the tube and may cause increased vehicle turning radius.
Dodge will fix your truck free of charge, Make sure dealer has parts in stock or to order the parts.
Safety Recall H46 Mopar Steering Linkage
Old Sep 5, 2009 | 10:06 PM
wildbill's Avatar
I got a card, just haven't set something up. Going to do it and the injectors at the same time.
Old Sep 5, 2009 | 11:46 PM
tower_ofpower's Avatar
dont waste your time if your truck doesnt need it; apparnetly it was for only certain style drag links; if your steering stabilizer bolts thru the drag link then there is no recall; however if it utilizes the bracket with the U clamps to secure it then the recall is applicable... otherwise the dealship will just tell you to whizz up a rope
Old Sep 6, 2009 | 12:06 AM
sidekick's Avatar
havent got the card yet but i do belive i got one the other week on the seatbelt though
Old Sep 6, 2009 | 02:50 AM
dontneedtostroke's Avatar
seatbelt? never got that one
Old Sep 6, 2009 | 03:05 AM
Captain Call's Avatar
Seatbelt??? What IS that?
Old Sep 6, 2009 | 03:12 AM
i never got the recall for my seatbelts
heck, i didnt even know my truck had seatbelts
Old Sep 6, 2009 | 07:12 PM
NadirPoint's Avatar
Originally Posted by tower_ofpower
...however if it utilizes the bracket with the U clamps to secure it then the recall is applicable... .
Actually, it depends on if the replacement u-bolt bracket is 15mm bolts. Some of the early dealer parts came with smaller, inferior hardware.
Old Sep 7, 2009 | 10:38 PM
Rebelmotorhead's Avatar
Default Yeah mine broke
I had just got done hauling a 30' camper that was loaded like a storage shed for a friend of mine and I no sooner pulled into the town I live in and the linkage had a crack and dropped the ball on the passenger side. Took it to the dealer for repair and got home, the recall was in the mailbox. Dealer said nothing about it till I called about the card. Apparently the recall is for a replacement linkage that may get installed at dealerships. I just happened to get mine changed around 16000 miles and got a bum one. The irony is they changed out the good factory one because they couldn't figure out a strange "bump" like feed back I was getting through my steering when the truck gets warmed up (especially when it's really hot out).
Old Sep 10, 2009 | 05:18 PM
chadillac's Avatar
I just took mine in because of grinding rt front they replaced uppper and lower ball joints, track bar and rt front hub.Used 4 wheel drive twice 40xxxx miles.Should i take it back???????????
