Autometer EGT help
Old Sep 1, 2009 | 05:26 PM
FastCR's Avatar
Default Autometer EGT help
okay I'm in class and have internet, so I'll ask.
I hooked up my autometer EGT gauge last night. I double checked all my wiring, but when I turn on the ignition, the gauge pegs CCW. This thing has been sitting around for awhile. would this be a bad module?
Old Sep 1, 2009 | 05:34 PM
mysterync's Avatar
Could be but are you sure the wiring is correct? Sometimes the plugs on the gauge will push out and cause it. Where are you grounding to?
Old Sep 1, 2009 | 05:55 PM
Def sounds like Electrical Issue.
Old Sep 1, 2009 | 06:01 PM
mysterync's Avatar
If it's not Luke and I will help you all we can. Even if you didnt buy it from us. We're commited to the members of DB. If we can help you fix a problem, even if you choose not purchase from us, We'll help you!
I hope everyone here know's that Luke and I have had many conversations, Our main goal here is to help grow DB and to help the members and staff anyway possible. Everyone here works together to make this a better site for you guys!
Make sure you ground to a good bare ground. If you are grounding where there is paint - scratch it off so you get good metal to metal contact with the ground lug.
Old Sep 1, 2009 | 06:02 PM
Check and RE-Check your connections.
Old Sep 1, 2009 | 10:51 PM
tower_ofpower's Avatar
just turn your gauge upside down... problem solved; now that luke and mysterync are going to slap me for not saying anything constructive at all grounds do funny things in electrical systems so as everyone one else has said check all your connections and go over your wiring again. and thanks for your services luke and mysternc; the site wouldnt be same w/o you guys and the rest of the sponsors
kevin krehel
18
May 14, 2015 05:07 PM
TurboBoy6.5
Apr 12, 2015 11:22 PM
Brappp306
Mar 29, 2015 08:54 PM
tbreddiesel
Thoroughbred Diesel
Feb 3, 2015 03:31 PM
offroad00
24
Oct 23, 2014 03:28 PM
