hesitation/ stumble
Old Aug 29, 2009 | 09:25 AM
shvlhead78's Avatar
Default hesitation/ stumble
my 2003 seems to want to die on occasion when leaving a dead stop.
new cps from recall and then installed another still doing it at random
I have no program installed removed it to see if that was the cause i
have installed a 6637 filter but problems were there before that. is it possible
since the air sensor, that sets in the old air box could be a factor there is no way
to really use it on the 6637 filter.
thanks
shvlhead
Old Aug 29, 2009 | 10:41 AM
wildbill's Avatar
Any codes??
Old Aug 29, 2009 | 01:42 PM
shvlhead78's Avatar
No dtc's found
Old Aug 29, 2009 | 02:35 PM
mysterync's Avatar
ICP Sensor, IDM Module...I guess the HPOP could cause this!
Old Aug 29, 2009 | 09:22 PM
shvlhead78's Avatar
thanks for the imput
Shvlhead78
Old Sep 1, 2009 | 08:30 PM
shvlhead78's Avatar
Fixed it . it was the ipr the nut fell off then the sleeve therfore it was sliding
on the shaft and not getting a signal at times.
sure did show signs of a bad cam sensor but after replacing that and with continued
problems continued looking, with the help of my neighbor a powerstsoke specialist for ford
he solved the problem.
Word to wise ol powerstroke owners the nut on the ipr can and will fall off into the valley. not that this is a common problem. i feel that it is good information for all
Thanks again
Shvlhead
Old Sep 1, 2009 | 09:29 PM
Excellent...your post will undoubtedly help someone else.
burndiesel
10
Feb 7, 2023 01:15 AM
2500ctd
Jun 23, 2016 01:22 AM
