12v lighting for gages
Old Aug 27, 2009 | 12:14 PM
GRI's Avatar
GRI
Default 12v lighting for gages
where is a quick easy way to hook gauges up to the lighting system so when the lights are on the gauge lights dim?
I spelt gauges, gages. in the title. dee dee dee
Old Aug 27, 2009 | 12:47 PM
wildbill's Avatar
Pull your a-pillar off and see if there is a connection to hook up clearance lamps.
Old Aug 27, 2009 | 01:15 PM
GRI's Avatar
GRI
I dont have chicken lights. That would just make the lights go on or off. I was kind of hoping to get them to dim when turned on, but that would mean they would be on all the time. hmmmmm
I guess I wil just have to have them on. Hopefully they arent to bright.
Old Aug 27, 2009 | 01:49 PM
DIESELDENT's Avatar
Tie the 12v power wire to the wire going from your dimmer to the factory gauges. Thats what i did on my 95.
Old Aug 27, 2009 | 02:58 PM
rkadcock's Avatar
N.M. Bombers Director
You can also use a fuse tap on the gauge cluster fuse. thats how my first set of gauges were wired on my 97
Old Aug 27, 2009 | 03:29 PM
GRI's Avatar
GRI
yeah I think I will try that. I may put a power switch in line with it so the lights on the gauges arent on all the time while driving
Old Aug 27, 2009 | 03:59 PM
jumpnjed's Avatar
I hookd mine up to the dimmer switch so that when i turned on the headlights the gauge lights came on and I could also dem the gauge lights. If im not mistaken there is a orange wire coming out of the fuse box for the dimmer switch.
Old Aug 27, 2009 | 04:20 PM
staarma's Avatar
Hooked mine to the dimmer. I believe it was an orange wire with brown trace. We both 04.5's so yours should be the same.
Old Sep 9, 2009 | 09:04 PM
GRI's Avatar
GRI
can you double check that and tell me where abouts you hooked into it?
I would appreciate it greatly
heres what they look like all lit up.
Old Sep 10, 2009 | 09:33 AM
staarma's Avatar
It is on the back of the headlight switch. You can see where the hanress plugs into the back of the dimmer wheel. The wire is an orange with a brown trace. You can test it with a test light. When you dim the wheel the test light will dim too.
