brakes???????????????
Old Aug 26, 2009 | 10:58 AM
wisconsin redneck's Avatar
Default brakes???????????????
i got a 95 dodge 2500 and i just put a 5" exhaust on it.. i took it for a test drive today.. and it was sweeett!!!... but the you have to push the pedal to the floor for the brakes to even begin to work... the ABS light is on and so is the BRAKE light... the parking brake isnt on and idk what it its... HELP!!!! its a scary f***n feeling go down the road barley able to stop...
Old Aug 26, 2009 | 12:03 PM
Whit's Avatar
Site Mascot
you need to inspect all 4 wheels ......sounds like they are shot
dont do it later do it now
Old Aug 26, 2009 | 01:10 PM
gradyc's Avatar
The first thing to check would be the fluid in the master cylinder.
Old Aug 27, 2009 | 09:04 AM
yeh well i checked the fuild shortly after posting the first post... and it ran out of fluid so i gues i need to bleed the system...... which im gonna do tonite after work... btw how do i do this?? haha thanks guys
Old Aug 27, 2009 | 11:12 AM
gradyc's Avatar
ABS systems usually have special bleeding procedures so you might need the manual for that one.I made a pressure bleeder that works from the wheels backward that works pretty well even on most ABS systems.
Old Aug 27, 2009 | 11:29 AM
wildbill's Avatar
I would count on having to replace the master cylinder. Running it out of fluid probably sent rust and other trash through, tearing up the rubber cubs.
Old Aug 27, 2009 | 12:05 PM
Johnny Z's Avatar
make sure that you dont have some rotted brake lines. That brake fluid went somwhere.
Old Aug 27, 2009 | 12:12 PM
K50's Avatar
K50
Yeah ditto on that. Inspect the whole system before you attempt to get back on the road!
Old Aug 28, 2009 | 09:42 AM
sh*t i just took it a local service shop and they said that all the brake lines are leaking and the booster is too... they gave me a quote of 400 for half a days work replacing them all and the booster... sound like a fair price???
Old Aug 28, 2009 | 10:43 AM
wildbill's Avatar
Figures out to around $60/hour. But what about parts??
