Torque converter lock up switch
Old Aug 23, 2009 | 05:46 PM
wyoranch's Avatar
Default Torque converter lock up switch
Ok guys, i know there was a thread on here before about a tc lockup switch on the 3rd gens but i cant find it. Ive got an '03 S.O. with the 47RE. Just put a billet tranny in it and im ready for a lockup switch. Anybody have a writeup on it?
Old Aug 25, 2009 | 04:49 AM
dontneedtostroke's Avatar
mystery switch 47re
its not the thread you were looking for but the top on will be the one you want to use, it says 96-02 on it but im pretty sure they changed transmissions halfway through 03 not 02(i could be wrong though) maybe someone else can confirm that or not
Old Aug 27, 2009 | 09:04 AM
wyoranch's Avatar
Well, the S.O. 03s like mine still have the 47 RE but the electronics are different. Ive done them on older ones and you end up just grounding out a specific wire. I found a writeup on the newer ones a year or two ago and did it to a buddys '05. It required putting a resistor in the line also, cant remember what size or exactly where
Old Aug 31, 2009 | 02:05 AM
25ohm 1/2 watt resistor on ground wire
Old Sep 1, 2009 | 03:54 AM
wyoranch's Avatar
Thanks. And what wire do i run it to?
Old Sep 4, 2009 | 05:10 AM
im not sure, i cant find the site i was reading it all from, but if you google 47re mystery switch you will get ALOT of sites to look at, alot are on DTR
Old Sep 4, 2009 | 06:25 AM
wildbill's Avatar
I'll crawl under my truck later today and see what color wire you splice into.
Or should I say the pin #.
Old Sep 6, 2009 | 06:08 AM
wyoranch's Avatar
Awesome, i appreciate it. I was looking at the 47re mystery switch but everything ive found is for a second gen with the 47re since theres not many 3rd gens with one. I figured since the electronics were probably the same as a 3rd gen 48re it would be the same as one of them. Its my understanding that on the 3rd gens the only diff between the 47 and 48 is the 47 has aluminum planetaries and the 48 has steel.
Old Sep 9, 2009 | 06:13 PM
TXAustin's Avatar
Is there somewhere that has a good proven way to do this to the 48re tranny? I have tried searching but not much luck.
Thanks, Austin
Old Sep 12, 2009 | 01:43 PM
cerberus60's Avatar
Thanks, Austin
Yes, tap the wire for pin #7 on the transmission control harness. Pin #'s are on the plug.
Run the wire to one side SPST switch.
Run the other side of the switch to a chassis ground, and, in the this leg place a 33 ohm 1/2 watt resistor.
Done, now you have a switch that will lock the TC in 2nd, 3rd, and OD on demand.
Couple of things to know about this though, much less than WOT and it will stack shift into OD.
No down shift from whatever the top gear is.
WILL break input shaft if not careful.
