what can i do to get power?
Old Aug 23, 2009 | 08:34 AM
94 CuMmInS's Avatar
Default what can i do to get power?
i have a 94 12v cummins. its pretty much stock just have intake and 4 in stack. what can i do to make good power ?
Old Aug 23, 2009 | 09:19 AM
wisconsin redneck's Avatar
first gauges.. (egt, boost, and tranny) then fuel plate to #100, star wheel full foward, afc housing full foward, straight pipe (if you havent already)
heres what he different fuel plates look like...
https://www.dieselbombers.com/12-val...-profiles.html
heres a cutaway of the p7100 pump
https://www.dieselbombers.com/12-val...ay-photos.html
heres a write up from DM... read it an i bet you will have no questions
https://www.dieselbombers.com/5-9l-1...2-valve-2.html
Old Aug 23, 2009 | 01:55 PM
94 12valve's Avatar
how much power do you want?
Old Aug 23, 2009 | 04:58 PM
94 CuMmInS's Avatar
well in the long run i wanna make 5 to the wheels
Old Aug 23, 2009 | 06:42 PM
To make 500hp your going to need all the things Redneck recommended plus Injectors, Turbo, Intake, plus a few other things.
Old Aug 23, 2009 | 09:27 PM
94 CuMmInS's Avatar
what do u have done to your 94 12valve? since your making 570
Old Aug 23, 2009 | 11:22 PM
94 12valve's Avatar
the stock 175 pump that I tweeked
II's dragon flows
air dogg 150
big stick cam
ported and oringed head
arp studs
intake
4" exhaust
sbc 3850 dual disk
s465 turbo
500 rwhp is simple here is how I would do it
remove your fuel plate
add 181dv's
add 2095 mack rack plug
4k gov springs
64/71/14 turbo
good set of injectors like a 5x12 should be fine
head studs
17-18* of timing
and make sure your trans will hold the power
Old Aug 24, 2009 | 12:23 AM
12valvetater's Avatar
you hit the nail right on the head again
Old Aug 24, 2009 | 04:02 PM
94 CuMmInS's Avatar
u mean jus remove fuel plate all together ? and wuts a 2095 mack rack plug?
Old Aug 24, 2009 | 04:13 PM
94 12valve's Avatar
yes just take it out and tune your afc. the 2095 rack plug is the 30 mm plug that is right behind the timing cover. It allowes an extra 2mm of rack travel which = more fuel
