Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
Jake Brake
Old Aug 16, 2009 | 09:37 PM
Gibby's Avatar
Default Jake Brake
Ok so the tanker i drive is a 95 fl112! im thinking it has a 3406! not positive cause i couldnt see the tag on top of motor! wore off! it has a lil over 700,000 miles! strong truck! problem im having is with the jake brake! you have the 2 cyl and the 4 cyl switches! the 2 cyl works! but the 4 cyl only seems like 2 cyl are working! every once in a blue moon the all work and darn it will hold it back! but once ya cut it off and the engine cools totally down all the jakes wont work! idk not good at this stuff but would like 4 it to work! thanks
Old Aug 16, 2009 | 09:48 PM
stkdram55's Avatar
first i would suspect the switch, easy first...but once you said it stops working after it cools all the way down it wont work at all, that is odd...ill have to think about CAT again its been only Cummins now at work for 2 years
Old Aug 16, 2009 | 10:04 PM
Begle1's Avatar
Good opportunity to pull the valve covers and manually actuate the Jakes.
Old Aug 16, 2009 | 10:42 PM
Gibby's Avatar
Ok so just pull the cover off! what do i look 4 once i get it off? how to manually acuate them? jw! have 2 step me thru this!
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
