06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
high boost pressure 07 duramax
Old Aug 15, 2009 | 03:19 PM
sbmax's Avatar
Default high boost pressure 07 duramax
I have an 07 GMC Duramax . It has an edge with attitude programmer,exhaust and air raid filter. The high boost limit buzzer on the programmer comes on with normal driving. Showing 35 psi. Could it be a wastegate issue? Thanks for any help.
Old Aug 16, 2009 | 01:13 PM
RSWORDS's Avatar
Whats teh buzzer set at? by normal driving what do you mean? Is this while getting up to speed or just crusing at 65?
Old Aug 16, 2009 | 06:19 PM
dieselboy04''s Avatar
The only duramax with a wastegate is the first gen LB7 from then on out it's the VVT turbos. Also if your hitting 35psi, That's not good..if it's like all the other VVT on the earlier dmaxs your over speeding it.. most times 32-33psi is all you wanna see coming from a stock turbo. also I don't know why the edge is boosting so high...but keep in mind this is newer technology then my truck so this could be normal, I hope someone with a new model truck will chime in and help your more so then I can.
Old Aug 16, 2009 | 07:01 PM
mysterync's Avatar
It's not normal with a edge juice only...Might try checking grounds and sending the box off to have it went through. What about the EGR and PCV system gunking up the turbo vanes and not allowing it to open? I've heard it happening more and more. I just got setup with a guy who makes the PCV delete kits.
Old Aug 17, 2009 | 10:12 PM
mikes454's Avatar
i hit 32-33psi all the time, but not sure if i'v ever seen 35.
BKID
Jul 25, 2015 07:59 PM
robbyS
Apr 16, 2015 02:22 PM
kraftsman
Ford Powerstroke 08-10 6.4L
Mar 4, 2015 02:00 PM
chaoticape
Jan 4, 2015 05:35 PM
Tsgbk9
Dec 23, 2014 11:54 AM
