hose to westgate valve
Old Aug 14, 2009 | 08:57 AM
dcgere2's Avatar
Default hose to westgate valve
when the vacum to the wesgate is hook up on my 2000 7.3 the da-- truck stumbles on it self can i get some help please? i did the filters .
Old Aug 17, 2009 | 08:04 PM
CSIPSD's Avatar
Not sure how the wastegate can cause stumbling... When does this happen? Is it while you are under boost?
Old Sep 20, 2009 | 02:03 PM
brettm's Avatar
YOU DONT NEED IT PUT IT ONTO ONE OF THE CLAMP STUDS you will get 7 to 8 more pounds of total boost and better mileage as well. hooked up i was 17 to 18 total boost unhooked total boost is at 23 to 26 depending on humudity and air temp. seems to have more boost when humidity is high and the lower the air temp the more boost you will get too.
RA113024
Mar 13, 2016 07:42 PM
markv8993
Jun 21, 2015 12:24 AM
LTreis702
Feb 14, 2015 12:52 PM
dieselpowa
Feb 7, 2015 10:07 PM
jrsavoie
Feb 6, 2015 09:44 PM
