6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
6.5 rebuild ideas
Old Aug 13, 2009 | 10:24 AM
rednekroper05's Avatar
Default 6.5 rebuild ideas
i have been thinking about rebuilding the engine in my 94 for awhile since it started that oil leak. Plus it had some pretty good blow-by. What would yall suggest as far as a good way to go for a rebuild. Im want to tweak it a lil a make some horsepower so i want to build it strong. Plus i need something to tinker with . any ideas?
TIA
Erskine
Old Aug 13, 2009 | 11:28 AM
6.5coalroller's Avatar
Cut those pistons down to 18:1 compression so you can run more boost safer and make sure to use ARP headstuds.
Old Aug 13, 2009 | 11:37 AM
yeah i was thinking lower comperssion. i was thinking of runnin a turbo simial to the one off my dodge also my plan includes a intercooler somehow. definatly ARP with out a doubt. another question for those that have torn these down is it true that #7 & 8 are often not the same bore as the others.
Old Aug 13, 2009 | 11:40 AM
I am currently puttin a hx 35 turbo off a cummins on my truck i'll put some pics of it on here when i'm done. I plan on gettin it done this weekend. Then I jus need a gl4 chip from heath to go along wit it.
Old Aug 13, 2009 | 11:54 AM
thanks i know the 6.5s aint powerhouse but i rember mine would roll some coal after the pump was tweaked a lil.
are you runnin or gonna run any kinda intercooler?
Old Aug 13, 2009 | 01:09 PM
DieselSlug's Avatar
So you just want to do this because? Let me tell you its a ton of work and a ton of money! I am in the middle of a build right now, and i didnt even tear the bottom end apart. Ive sunk prolly about 2k into this engine and its still built stock, except for the arp headstuds. From what ive heard its getting harder to come across the mahle 18-1 compression pistons. It costs a lot of money to go that route! I know a guy that has done it. The pistons in each hole is the same, i just replace a burnt one in mine. Who told you they were different? A lot of thought has to go into it. Most 6.5's have blowby, its not the end of the world. Even fairly rebuilt ones have it. Its common, even if you have a lot these engines still go for a long time. You really dont need an intercooler unless you live in a very hot climate. Remember intercoolers are worthless when you are sitting. How many miles does your engine have? I would just tm it, chip it, and maybe a more efficient turbo.
Old Aug 13, 2009 | 02:07 PM
I'd like to get an intercooler later on in case I pull somethin with it, but i'd really lyk to get it chipped out and get a guage set.
I think it'd be cheaper to have your old pistons cut down instead of buyin new ones to get the lower compression. You'd definitley need that chip the marine injectors and a heavy duty lift pump to get enough fuel to it if you put any more boost through it. If you had an intercooler and methanol injection also that would be one sweet six five if it held together. If I was gonna spend that much money on a motor I'd jus buy a cummins and hop it up and make 2 or 3 times the power and drop it in the truck. Thats what i'm gonna do in tech school while i'm in the high performance class.
Old Aug 13, 2009 | 02:37 PM
i know i was thing about possibly going with cummins but some thing in me kinda wants to see how far i really can push the 6.5 and keep it relaible. and maybe if i can find a good cheap cummins i still might. plus the cost of just building and buying all the lil stuff to put a cummins in there kinda out weighs a 6.5 rebuild.
Old Aug 13, 2009 | 03:15 PM
DieselSlug's Avatar
THe pistons have a special coating on the top of them, if you have ever seen one it is like a black center with a metal ring around it. (The colors make it look like that). I just ook one out of my new engine since it was burnt and had a guy send me a used one, he grinded it down!! The protective layer was chewed off, so i would have had 7 cyls. with good compression, and 1 with less. I now use it as a paperweight... I wouldnt shave them....
If i had a lot of money i would put a cummins in mine, but its just not practical. THen your truck turns into custom. And for a daily driver a custom truck isnt as reliable as something from the factory, within reason. If your a fabricator that will help you even more. But sadly im not....
Last edited by DieselSlug; Aug 13, 2009 at 03:15 PM. Reason: Automerged Doublepost
Old Aug 13, 2009 | 03:29 PM
yeah i figure after i buy a good 12v and refresh it a lil then shoehorn it in i will have somewhere between 4-5k invested easily.
